I get to the part where it says to set GPS to autostart and but /dev/cdc-wdm0 doesn’t enumerate.
Here is the minicom log
AT
AT!USBCOMP?
Config Index: 1
Config Type: 4 (MBIM V2)
Interface bitmask: 00001009 (diag,modem,mbim)
AT!CUSTOM?
!CUSTOM:
GPSENABLE 0x01
GPSSEL 0x01
IMCONFIG 0x02
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
SCRUBEN 0x01
CSDDISABLE 0x01
ICMPINTSRVDIS 0x01
SIMLPA 0x01
AT!GPSAUTOSTART=1
dmesg shows this:
~$ sudo dmesg | grep usb
[ 0.291543] usbcore: registered new interface driver usbfs
[ 0.291543] usbcore: registered new interface driver hub
[ 0.291543] usbcore: registered new device driver usb
[ 0.552359] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.11
[ 0.552361] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.552363] usb usb1: Product: xHCI Host Controller
[ 0.552364] usb usb1: Manufacturer: Linux 6.11.3-200.fc40.x86_64 xhci-hcd
[ 0.552366] usb usb1: SerialNumber: 0000:00:0d.0
[ 0.552475] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.11
[ 0.552477] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.552479] usb usb2: Product: xHCI Host Controller
[ 0.552480] usb usb2: Manufacturer: Linux 6.11.3-200.fc40.x86_64 xhci-hcd
[ 0.552481] usb usb2: SerialNumber: 0000:00:0d.0
[ 0.554581] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.11
[ 0.554583] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.554585] usb usb3: Product: xHCI Host Controller
[ 0.554586] usb usb3: Manufacturer: Linux 6.11.3-200.fc40.x86_64 xhci-hcd
[ 0.554587] usb usb3: SerialNumber: 0000:00:14.0
[ 0.555896] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.11
[ 0.555898] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.555899] usb usb4: Product: xHCI Host Controller
[ 0.555901] usb usb4: Manufacturer: Linux 6.11.3-200.fc40.x86_64 xhci-hcd
[ 0.555902] usb usb4: SerialNumber: 0000:00:14.0
[ 0.556471] usbcore: registered new interface driver usbserial_generic
[ 0.556475] usbserial: USB Serial support registered for generic
[ 0.565882] usbcore: registered new interface driver usbhid
[ 0.565886] usbhid: USB HID core driver
[ 0.797730] usb 3-7: new full-speed USB device number 2 using xhci_hcd
[ 0.928293] usb 3-7: New USB device found, idVendor=0cf3, idProduct=e600, bcdDevice= 0.01
[ 0.928682] usb 3-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.509156] usbcore: registered new interface driver cdc_wdm
[ 3.512541] usbcore: registered new interface driver cdc_ether
[ 3.516899] usbcore: registered new interface driver cdc_ncm
[ 3.518707] usbcore: registered new interface driver cdc_mbim
[ 3.521726] usbcore: registered new interface driver qmi_wwan
[ 3.523307] usbcore: registered new interface driver qcserial
[ 3.523741] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.524152] usbserial: USB Serial support registered for Qualcomm USB modem
[ 3.921939] Modules linked in: sunrpc rapl intel_cstate btmtk bluetooth intel_uncore processor_thermal_mbox mei spi_intel_pci soundcore i2c_i801 cec wmi_bmof int340x_thermal_zone spi_intel i2c_smbus intel_soc_dts_iosf intel_pmc_core intel_vsec int3400_thermal pmt_telemetry fjes(-) pmt_class acpi_thermal_rel acpi_tad acpi_pad mhi_pci_semtech(OE) qcserial(OE) qmi_wwan(OE) usb_wwan(OE) cdc_mbim cdc_ncm cdc_ether cdc_wdm usbnet mii ath11k_pci(OE) mhi(OE) ath11k(OE) mac80211 libarc4 cfg80211 rfkill qmi_helpers nfnetlink overlay xfs nvme_tcp crct10dif_pclmul crc32_pclmul crc32c_intel nvme_fabrics polyval_clmulni nvme polyval_generic nvme_keyring nvme_core ghash_clmulni_intel sha512_ssse3 sha256_ssse3 igc sha1_ssse3 wdat_wdt nvme_auth video wmi pinctrl_tigerlake be2iscsi bnx2i cnic uio cxgb4i cxgb4 tls cxgb3i cxgb3 mdio libcxgbi libcxgb qla4xxx iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi scsi_dh_rdac scsi_dh_emc scsi_dh_alua ip6_tables ip_tables fuse dm_multipath
[ 4.006038] usbcore: registered new interface driver btusb
tail of dmesg
[ 7.558489] fbcon: i915drmfb (fb0) is primary device
[ 9.797194] Console: switching to colour frame buffer device 240x67
[ 9.821421] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 24.124080] systemd-journald[1013]: /var/log/journal/ed135f74695646ad9803f565ac5d4449/user-1000.journal: Journal file uses a different sequence number ID, rotating.
ls of /dev
$ ls /dev
acpi_thermal_rel cpu_dma_latency fd kmsg mhi0_QDSS nvme0 pps0 ptp2 shm tty10 tty19 tty27 tty35 tty43 tty51 tty6 ttyS1 ttyS18 ttyS26 ttyS6 usbmon1 vcs4 vcsa6 vga_arbiter wwan0qmi0
autofs disk full kvm mqueue nvme0n1 pps1 ptp3 snapshot tty11 tty2 tty28 tty36 tty44 tty52 tty60 ttyS10 ttyS19 ttyS27 ttyS7 usbmon2 vcs5 vcsu vhci zero
block dma_heap fuse log mtd nvme0n1p1 pps2 ptp4 snd tty12 tty20 tty29 tty37 tty45 tty53 tty61 ttyS11 ttyS2 ttyS28 ttyS8 usbmon3 vcs6 vcsu1 vhost-net
btrfs-control dri gpiochip0 loop-control mtd0 nvme0n1p2 pps3 ptp5 stderr tty13 tty21 tty3 tty38 tty46 tty54 tty62 ttyS12 ttyS20 ttyS29 ttyS9 usbmon4 vcsa vcsu2 vhost-vsock
bus drm_dp_aux0 hpet mapper mtd0ro nvme0n1p3 pps4 pts stdin tty14 tty22 tty30 tty39 tty47 tty55 tty63 ttyS13 ttyS21 ttyS3 udmabuf userfaultfd vcsa1 vcsu3 watchdog
char drm_dp_aux1 hugepages mcelog net nvme0n1p4 pps5 random stdout tty15 tty23 tty31 tty4 tty48 tty56 tty7 ttyS14 ttyS22 ttyS30 uhid vcs vcsa2 vcsu4 watchdog0
console drm_dp_aux2 hwrng mei0 ng0n1 nvram ptmx rfkill tty tty16 tty24 tty32 tty40 tty49 tty57 tty8 ttyS15 ttyS23 ttyS31 uinput vcs1 vcsa3 vcsu5 wwan0at0
core drm_dp_aux3 initctl mem null port ptp0 rtc tty0 tty17 tty25 tty33 tty41 tty5 tty58 tty9 ttyS16 ttyS24 ttyS4 urandom vcs2 vcsa4 vcsu6 wwan0mbim0
cpu drm_dp_aux4 input mhi0_IP_HW_ADPL nvme-fabrics ppp ptp1 rtc0 tty1 tty18 tty26 tty34 tty42 tty50 tty59 ttyS0 ttyS17 ttyS25 ttyS5 usbmon0 vcs3 vcsa5 vfio wwan0qcdm0
VBUS_SENSE is pulled to 3.3V, PCIE_DIS is floating.
