After an update attempt, my EM9191 seems to stuck in an inconsistent firmware state with parts of old and parts of new firmware. The modem remains disabled. It also denies further download attempts. What can I do?
The log of the latest attempt is attached. The previous attempts I did not log and it showed some similar but different error.
$ sudo ./download -f fw -n SWIX55C_02.08.01.00_GENERIC_020.007_001.nvu -w SWIX55C_02.08.01.00_002.cwe -d /dev/ttyUSB0
Application version: 1.0.2109.0
INFO: QDL Port : /dev/ttyUSB0
INFO: Device Path:
INFO: FW Path : fw
Target image Info:
Carrier :GENERIC
FW Version :02.08.01.00
Model ID :SWIX55C
Package ID :001
PRI Version:020.007
SKU :9999999
Modem is in QDL mode. Continuing FW download
Waiting for modem to come up in BOOT and HOLD mode ...
BOOT and HOLD Mode. Downloading firmware ...
FW download failed: eSDP_FWDWL_ERR_OUT_OF_SYNC(117)
Device not responsive in download mode. Please power cycle device.
Exiting Application!!!
The fwdl.log:
[217][1]System date/time: 26/10/2021 16:20:48
[217][1]1.0.2109.0
[217][1]Kernel: Linux rme-appPC6 5.4.0-89-generic #100-Ubuntu SMP Fri Sep 24 14:50:10 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
[217][1]qcserial version: 1.9.2108.3
[217][1]usb_wwan version: 1.0.2101.1
[217][1]cdc_mbim srcversion: E78127BCABE41799AC5303D
[217][1]qmi_wwan version: 1.3.2108.2
[217][1]Unable to log mhictrl version info. Drivers from MBPL R17 or newer are required.
[217][1]Unable to log mhinet version info. Drivers from MBPL R17 or newer are required.
[217][1]Unable to log mhitty version info. Drivers from MBPL R17 or newer are required.
[217][1]./download
[217][1]-f
[217][1]fw
[217][1]-n
[217][1]SWIX55C_02.08.01.00_GENERIC_020.007_001.nvu
[217][1]-w
[217][1]SWIX55C_02.08.01.00_002.cwe
[217][1]-d
[217][1]/dev/ttyUSB1
[217][1]-m
[217][1]4
[217][7]User specified read block size: 0 bytes
[217][7]**************************************************
[217][7]Copyright: © 2015-2017 Sierra Wireless, Inc. all rights reserved
[217][7]lite-fw is only permitted to be used with Sierra Wireless Modems
[217][7]lite-fw version lite-fwMBPL_SDK_R23_ENG4
[217][6]Images list:
[217][6]Image[0]: fw/SWIX55C_02.08.01.00_GENERIC_020.007_001.nvu
[217][6]Image[1]: fw/SWIX55C_02.08.01.00_002.cwe
[217][6]Device is in BOOT&HOLD mode.
[217][7]Waiting for modem to come up in B&H mode ...
[218][7]Modem is in B&H mode. Downloading firmware ...
[218][7]find_dev_ss_loc: Found device SS path '/sys/bus/usb/devices/1-8.2/power/control'
[218][7]disable_ss: SS is not enabled, no need to disable SS.
[218][7]QDL Port :/dev/ttyUSB1
[223][7]read timeout
[223][7]Read payload [0]
[223][7]Read 0 bytes
[223][7]
[223][7]Sahara HELLO message might be missed. Resending Sahara HELLO response.
[223][7]Current mode: 0, previous max_reads_allowed: 29
[223][7]Send 48 bytes
[223][7]02 00 00 00 30 00 00 00 02 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00 01 00 00 00 02 00 00 00
[223][7]03 00 00 00 04 00 00 00 05 00 00 00 06 00 00 00
[223][7]Sahara Hello Rsp sent successfully, max_reads_allowed reset to 30
[224][7]read timeout
[224][7]Read payload [0]
[224][7]Read 0 bytes
[224][7]
[224][3]Device not responsive to SAHARA HELLO RESPONSE, need a power cycle.
Power cycling did not help. The AT port still works though:
at!gstatus?
!GSTATUS:
Current Time: 436 Temperature: 38
Reset Counter: 1 Mode: LOW POWER MODE
ati
Model: EM9191
Revision: SWIX55C_01.07.08.00 000000 jenkins 2020/11/16 10:11:33
IMEI: 355890340153001
IMEI SV: 4
FSN: 8W1042009502A1
+GCAP: +CGSM
at!priid?
PRI Part Number: 9909738
Revision: 001.007
Customer: Generic
Carrier PRI: None
at+cgmr
At!impref?
!IMPREF:
preferred fw version: 02.08.01.00
preferred config name: GENERIC_020.007_001
preferred subpri index: 000
current fw version: 01.07.08.00
current carrier name: GENERIC
current config name: GENERIC_016.003_000
current subpri index: 000
fw version mismatch
config name mismatch
AT!PCINFO?
State: Low Power Mode
LPM voters - Temp:0, Volt:0, User:0, W_DISABLE:0, IMSWITCH:1, BIOS:0, LWM2M:0, OMADM:0, FOTA:0, RFCAL:0
LPM persistence - None
