root@HP:/home/admin1/Downloads/MBPL_SDK_R30_ENG6-lite.bin/SampleApps/lite-fw-download/bin# ./fwdwl-litehostx86_64 -f /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000
Application version: 1.0.2211.2
INFO: QDL Port:
INFO: Device Path: /dev/cdc-wdm2
INFO: FW Path: /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000
Target image Info:
Carrier :GENERIC
FW Version :03.10.07.00
Model ID :SWIX55C
Package ID :000
PRI Version:030.062
SKU :9999999
Switching device into download mode …
Modem Needs FW
Modem Needs PRI
Waiting for modem to disconnect from the host …
Modem disconnected from host.
Waiting for modem to come up in BOOT and HOLD mode …
QDL port found: /dev/ttyUSB0
BOOT and HOLD Mode. Downloading firmware …
Downloading: /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000/SWIX55C_03.10.07.00-001.cwe
Downloading: /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000/SWIX55C_03.10.07.00-001_GENERIC_030.062_000.nvu
All image data was downloaded successfully.
Device is about to reset …
Waiting for modem to come up in ONLINE mode …
Failed to detect modem ONLINE mode in 240 seconds. Application terminates.
After I use your method the result is like this, please help me!
root@HP:/home/admin1/Downloads/MBPL_SDK_R30_ENG6-lite.bin/SampleApps/lite-fw-download/bin# ./fwdwl-litehostx86_64 -c MBIM -m 4 -d /dev/ttyUSB0 -p /dev/cdc-wdm0 -f /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000/ -t 1 -w SWIX55C_03.10.07.00-001.cwe -n SWIX55C_03.10.07.00-001_GENERIC_030.062_000.nvu -l log.txt
INFO: QDL Port: /dev/ttyUSB0
INFO: Device Path: /dev/cdc-wdm0
INFO: FW Path: /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000/
Target image Info:
Carrier :GENERIC
Model ID :SWIX55C
Package ID :000
PRI Version:030.062
SKU :9999999
Modem is already in QDL mode. Continuing FW download
FW download failed: eSDP_FWDWL_ERR_SAHARA_UNRESPONSIVE(122)
Device not responsive in download mode. Please power cycle device.
what is the current FW version in ATI3 in your module?
does your module work in Windows?
You might also need to try AT!BOOTHOLD to kick module into download mode first: sudo ./bin/fwdwl-litehostx86_64 -c QMI -m 4 -d /dev/ttyUSB0 -f /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000/
EM9190 is recognized by windows, but it doesn’t work when installing fw, like linux
I used AT!BOOTHOLD before and here are the results:
root@HP:/home/admin1/Downloads/MBPL_SDK_R30_ENG6-lite.bin/SampleApps/lite-fw-download/bin# ./fwdwl-litehostx86_64 -c QMI -m 4 -d /dev/ttyUSB0 -f /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000/
INFO: Device Path:
Target image Info:
Carrier :GENERIC
Model ID :SWIX55C
Package ID :000
PRI Version:030.062
SKU :9999999
Downloading: /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000//SWIX55C_03.10.07.00-001.cwe
Downloading: /home/admin1/Downloads/SWIX55C_03.10.07.00-001_GENERIC_030.062_000//SWIX55C_03.10.07.00-001_GENERIC_030.062_000.nvu
