We have EM9291 sierra module.
Is it possible to increase power of this module ?
do you mean TX power?
If this is using live network, it is controlled by the 3GPP specification.
Hi @jyijyi ,
We are currently evaluating the EM9291 module in N28 band with max power. We have a requirement for higher TX power module to meet our long-range (10 KM) communication needs. Could you please suggest an alternative module with higher TX power that can address this requirement? We would appreciate your prompt support.
Hi @jyijyi ,
Thanks for the quick update.
We are still working on the output power of our base station, but we would like to understand whether we can improve the TX power of our UE.
as mentioned before, this TX power of n28 is bounded by the power class 3
Do you recommend any alternative module?
as mentioned before, n28 is included in Power class 3, and the output power is 23dbm
Our Aim is long distance, we are open to using any frequency band. Do you have any suggestion in this case?
Hi @jyijyi ,
can you please share this document link?
you can find the specification here:
https://source.sierrawireless.com/resources/airprime/minicard/airprime_em92xx_product_technical_specification/#sthash.GtwbiGpv.dpbs
Hello Jyijyi,
To continue on this, we are currently facing a UE re-attach issue after detach with the Vicinity 5G system using the EM9291 Sierra module.
The Vicinity team has observed that the UE initiates IMS PDU establishment during the first attach, which prevents successful re-attach after detach. They have suggested disabling IMS on the UE.
Could you please guide us on how to disable IMS on the UE?
Best regards,
Sahil
You can try at!imstestmode command
Hello Jyijyi,
We checked the AT command you shared, and it returns “IMS Test Mode Disabled” by default.
Could you please confirm whether there are any additional settings required to disable IMS PDU (for VoNR)?
Best regards,
Sahil
Test mode disabled means it will register IMS …
Hello Jyijyi,
Thanks for the clarification.
We enabled IMS test mode to disable IMS registration as per the suggestion from the Vicinity 5G team. However, after this change, we are not able to connect to the Vicinity 5G network.
Could you please help us understand the behavior of enabling IMS test mode?
Best regards,
Sahil
Then you should check with Vinicity in why they suggest like this
Normally i will not disable ims mode
