I remember I used IPERF to generate traffic.
Also please make sure the testing area is having 5G.
ATi3
Model: EM9191
Revision: SWIX55C_03.09.03.00 b23ca1 jenkins 2022/02/18 00:29:11
IMEI: 355890340412345
IMEI SV: 21
FSN: 8W127402123123
+GCAP: +CGSM
AT!entercnd="A710"
+DMI: Authentication Failed; Server ID: 1000
+DMI: Authentication Start; Server ID: 1000
AT!impref?
!IMPREF:
preferred fw version: 03.09.03.00
preferred carrier name: VERIZON
preferred config name: VERIZON_030.033_001
preferred subpri index: 000
current fw version: 03.09.03.00
current carrier name: VERIZON
current config name: VERIZON_030.033_001
current subpri index: 000
AT!LTEINFO?
!LTEINFO:
Serving: EARFCN MCC MNC TAC CID Bd D U SNR PCI RSRQ RSRP RSSI RXLV
5230 311 480 33802 02063503 13 3 3 15 200 -12.8 -67.2 -37.8 --
IntraFreq: PCI RSRQ RSRP RSSI RXLV
InterFreq: EARFCN ThresholdLow ThresholdHi Priority PCI RSRQ RSRP RSSI RXLV
CA SCell : EARFCN SCID Bd ST D U Mdl Mul PCI RSRP RSSI SINR
WCDMA: UARFCN ThreshL ThreshH Prio PSC RSCP ECN0 RXLV
AT!NRINFO?
!NRINFO:
Connectivity Mode: NSA
NR5G Cell ID: 199
NR5G band: n2 NR5G Carrier ID: 0
NR5G dl bw: 15 MHz NR5G ul bw: 15 MHz
NR5G Tx Power: -13 NR5G Tx chan: 371540
NR5G Rx chan: 387540
NR5G dl MIMO: 4 NR5G ul MIMO: 1
NR5G(sub6) RxM RSSI (dBm): -39.8 NR5G(sub6) RxD RSSI (dBm): -49.0
NR5G(sub6) RxM1 RSSI (dBm): -43.5 NR5G(sub6) RxD1 RSSI (dBm): -41.0
NR5G RSRP (dBm): -72 NR5G RSRQ (dB): -11
NR5G SINR (dB): 22.5
AT!GSTATUS?
!GSTATUS:
Current Time: 1300 Temperature: 34
Thermal Mitigation Level: 0
Reset Counter: 1 Mode: ONLINE
System mode: ENDC PS state: Attached
LTE band: B13 LTE bw: 10 MHz
LTE Rx chan: 5230 LTE Tx chan: 23230
EMM state: Registered Normal Service
RRC state: RRC Connected
IMS reg state: REGISTERED IMS mode: Normal
IMS Srv State: FULL SMS,UNKNOWN VoIP
PCC RxM RSSI: -35 PCC RxM RSRP: -65
PCC RxD RSSI: --- PCC RxD RSRP: ---
PCC Tx Power: -15 TAC: 840a (33802)
RSRQ (dB): -12.8 Cell ID: 02063503 (33961219)
SINR (dB): 17.2
SCC1 NR5G band: n2 SCC1 NR5G bw: 15 MHz
SCC1 NR5G Tx Power: 9 SCC1 NR5G Tx chan: 371540
SCC1 NR5G Rx chan: 387540
NR5G RSRP (dBm): -71 NR5G RSRQ (dB): -11
NR5G SINR (dB): 23.0
