EM7511 module and Italian operator
Hi, I purchased a laptop with an EM7511 module installed for internet browsing. I tried to insert a SIM from a local operator “Italy” but it doesn’t work. A doubt arises in my mind, reading the characteristics of the module it seems that the 7511 is compatible in America. Is it possible to make it work in Italy too or do I have to replace the module? If I have to replace it, which module could I use to connect to an operator in Italy?
Thank you
Luca
Did you check if the supported band available in italy?
What are the return of the followings?
Ati3
At!impref?
At!gstatus?
At+cgdcont?
At!selrat?
At!band?
AT!uims?
yes the band is supported
AT!IMPREF?
!IMPREF:
preferred fw version: 01.07.02.00
preferred carrier name: ATT
preferred config name: ATT_002.008_004
current fw version: 01.07.02.00
current carrier name: ATT
current config name: ATT_002.008_004
!GSTATUS:
Current Time: 1405 Temperature: 35
Reset Counter: 2 Mode: ONLINE
System mode: WCDMA PS state: Not attached
WCDMA band: WCDMA 2100
WCDMA channel: 10563
MM (CS) state: IDLE LIMITED SERVICE
WCDMA L1 state:L1M_SUSPENDED LAC: 5fdb (24539)
RRC state: DISCONNECTED UTRAN Cell ID: 009207f1 (9570289)
RxM RSSI C0: — RxD RSSI C0: —
RxM RSSI C1: — RxD RSSI C1: —
AT+CGDCONT?
+CGDCONT: 1,“IPV4V6”,“broadband”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Following connection profiles are available,
CID-> 1
PDP Type->IPV4V6
APN->broadband
PDP Address->0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
Data Compression->0
Header Compression->0
CID-> 2
PDP Type->IPV4V6
APN->
Data Compression->0
CID-> 3
PDP Type->IPV4V6
APN->
Data Compression->0
AT!SELRAT?
!SELRAT: 00, Automatic
AT!BAND?
Index, Name
06, Europe
AT!UIMS?
!UIMS: 0
the FW is very old, and I am not quite sure why it is using ATT PRI.
I think you should use the GENERIC PRI with GCF approved
https://source.sierrawireless.com/resources/airprime/minicard/75xx/em_mc75xx-approved-fw-packages/#sthash.ZgFQbkts.WRIYRIXW.dpbs
Also you need to set the correct APN in AT+CGDCONT.
Thank you very much for helping jyijyi.
With the new driver it works perfectly … he immediately hooked the operator line.
