After staying powered off through the night, I booted the FZ-G1 up today and the LTE was in No Service mode. I re-ran the commands and here are the results. I can see the card is now reporting Low Power Mode and the AT!IMPREF? command produced different results. Appreciate any advice on this.
Send:AT!entercnd=“A710”
Recieve: AT!entercnd=“A710”
Recieve: OK
Send:AT!bsinfo
Recieve: AT!bsinfo
Recieve: Product: EM7455B
Recieve: Revision: 40
Recieve: Main: MDM9230 (002)
Recieve: Radio: WTR3925
Recieve: Power: PMD9635 (001)
Recieve: Flash: MT29F4G08ABBFA3W 512MB x8 (44/0/0) (2048 blocks of 64 pages/block 4096B page size)
Recieve: OK
Send:ati3
Recieve: ati3
Recieve: Manufacturer: Sierra Wireless, Incorporated
Recieve: Model: EM7455B
Recieve: Revision: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30
Recieve: MEID: A10000747A77B3
Recieve: ESN: 12802473253, 8025BD25
Recieve: IMEI: 990008248678968
Recieve: IMEI SV: 20
Recieve: FSN: LF221352440110
Recieve: +GCAP: +CGSM
Recieve: OK
Recieve: AT!IMPREF?
Recieve: !IMPREF:
Recieve: preferred fw version: 02.30.01.01
Recieve: preferred carrier name: VERIZON
Recieve: preferred config name: VERIZON_002.052_002
Recieve: preferred subpri index: 000
Recieve: current fw version: 02.33.03.00
Recieve: current carrier name: VERIZON
Recieve: current config name: VERIZON_002.079_002
Recieve: current subpri index: 000
Recieve: fw version mismatch
Recieve: config name mismatch
Recieve: OK
Send:AT!gstatus?
Recieve: AT!gstatus?
Recieve: !GSTATUS:
Recieve: Current Time: 326 Temperature: 41
Recieve: Reset Counter: 2 Mode: LOW POWER MODE
Recieve: OK
Send:AT+cpin?
Recieve: AT+cpin?
Recieve: +CPIN: READY
Recieve: OK
Send:AT!UIMS?
Recieve: AT!UIMS?
Recieve: !UIMS: 0
Recieve: OK
Send:AT!band?
Recieve: AT!band?
Recieve: Index, Name, GW Band Mask L Band Mask TDS Band Mask
Recieve: 00, All bands, 0002000007C00000 000000000000101A 0000000000000000
Recieve: OK
Send:AT!selrat?
Recieve: AT!selrat?
Recieve: !SELRAT: 00, Automatic
Recieve: OK
Send:AT!image?
Recieve: AT!image?
Recieve: TYPE SLOT STATUS LRU FAILURES UNIQUE_ID BUILD_ID
Recieve: FW 1 GOOD 1 0 0 ?? 02.20.03.00?
Recieve: FW 2 GOOD 2 0 0 ?? 02.33.03.00?
Recieve: FW 3 EMPTY 0 0 0
Recieve: FW 4 EMPTY 0 0 0
Recieve: Max FW images: 4
Recieve: Active FW image is at slot 255
Recieve: PRI FF GOOD 0 0 0 002.017_002 02.20.03.00_GENERIC
Recieve: PRI FF GOOD 0 0 0 002.079_002 02.33.03.00_VERIZON
Recieve: Max PRI images: 50
Recieve: OK
Send:AT+CGDCONT?
Recieve: AT+CGDCONT?
Recieve: +CGDCONT: 1,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Recieve: +CGDCONT: 2,“IPV4V6”,“vzwadmin”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Recieve: +CGDCONT: 3,“IPV4V6”,“vzwinternet”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Recieve: +CGDCONT: 4,“IPV4V6”,“vzwapp”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Recieve: +CGDCONT: 5,“IPV4V6”,“vzw800”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Recieve: +CGDCONT: 6,“IPV4V6”,“vzwclass6”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
Recieve: OK
