Installed latest drivers. Modem detection in Device Manager works OK. It does see the SIM installed. But I cannot add an APN to it:
Are you using the TMO version of FW?
I guess it has been set by default…
You can check in AT command port AT+CGDCONT?
I tried both Generic and T-Mobile firmwares with the same result.
did you check AT+CGDCONT?
Did you check AT!GSTATUS? and see if the module can register network?
The module is registered to the network.
+CGDCONT: 1,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
!GSTATUS:
Current Time: 529 Temperature: 22
Reset Counter: 1 Mode: ONLINE
LTE band: B12 LTE bw: 5 MHz
LTE Rx chan: 5035 LTE Tx chan: 23035
LTE SCC1 state:NOT ASSIGNED
LTE SCC2 state:NOT ASSIGNED
LTE SCC3 state:NOT ASSIGNED
LTE SCC4 state:NOT ASSIGNED
RRC state: RRC Idle
IMS reg state: No Srv
by default, it should have the following:
at!impref?
!IMPREF:
preferred fw version: 01.14.03.00
preferred carrier name: TMO
preferred config name: TMO_002.005_003
preferred subpri index: 000
current fw version: 01.14.03.00
current carrier name: TMO
current config name: TMO_002.005_003
current subpri index: 000
at+cgdcont?
+CGDCONT: 1,"IPV6","fast.t-mobile.com","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
ati3
Model: EM7411
Revision: SWI9X50C_01.14.03.00 b06bd3 jenkins 2020/09/23 10:53:35
IMEI: 356280111412345
IMEI SV: 13
FSN: 8F223322912345
+GCAP: +CGSM
BTW, I don’t see problem to add APN under MBIM mode:
