- I can see the output of
sudo mmcli -m 0as follows,
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: a13799d4536930cbcbdc2afeg8j3104c57069ae0
Hardware | manufacturer: Sierra Wireless, Incorporated
| model: Sierra Wireless EM7455 Qualcomm® Snapdragon™ X7 LTE-A
| revision: SWI9X30C_02.32.11.00
| h/w revision: EM7455
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 35905626987854
System | device: /sys/devices/pci0000:00/0000:00:15.0/usb1/1-7
| drivers: qcserial, cdc_mbim
| plugin: Sierra
| primary port: cdc-wdm0
| ports: ttyUSB0 (qcdm), ttyUSB2 (at), cdc-wdm0 (mbim),
| wwp0s21f0u7i12 (net)
Numbers | own: 07574391674
Status | unlock retries: sim-pin2 (3)
| state: registered
| power state: on
| access tech: hsdpa, hsupa
| signal quality: 32% (cached)
Modes | supported: allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| current: allowed: 3g, 4g; preferred: 4g
Bands | supported: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
| eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7, eutran-8,
| eutran-12, eutran-13, eutran-20, eutran-25, eutran-41
| current: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: -------------
| enabled locks: fixed-dialing
| operator id: ----
| operator name: EE
| registration: home
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
Bearer | dbus path: /org/freedesktop/ModemManager1/Bearer/2
but when I use
sudo mmcli -m 0 --simple connect="apn=apn=apn.com,user=username,password=password"
I am getting the following response
error: couldn't connect the modem: 'GDBus.Error:org.freedesktop.libmbim.Error.Status.ServiceNotActivated: ServiceNotActivated'
I also tried to create a bearer, but error. -
Is this the way to add APN settings to the modem ?
