EM 7565 firmware supporting at test commands
Dear friends,
I am testing EM 7565 modules.
For some reason, I would like to test the capability of modem, such as its selected band/channels/any other command in factory test mode.
In At command guide, There are some command starting with “!da…”, e.g., “!daftmact”, “!dasband”, “!daschan” …
Is there anybody who has the firmware supporting these test commands?
Or Do you know ANY FUTURE PLAN for the commands to be updated?
Thanks in advance!
Kevin
Hi Kevin,
Factory test commands are included in the FW.
at!entercnd=“A710”
at!daftmact
290300
Which one is not working for you?
thanks,
James
Thanks, James!
I can use “at!daftmact” and “at!daftmdeact”, but those are all i can do. ^^
--------- log ------------------
ati
Model: EM7565
Revision: SWI9X50C_01.08.04.00 dbb5d0 jenkins 2018/08/21 21:40:11
IMEI: 359260080166652
IMEI SV: 8
FSN: UF823287100110
+GCAP: +CGSM,+DS,+ES
at!entercnd=“A710”
at!daftmact
290300
at!dasband?
!DASBAND: NOT IMPLEMENTED
at!daschan?
!DASCHAN: NOT IMPLEMENTED
-------log end ----------------------
Am I missing some pre-requisites for using other test commands?
Any comment will be appreciated.
(Thanks, James in advance!)
Best Regards, Kevin
Hi Kevin,
The AT guide has the old/obsolete FTM commands, we are working on an update.
please read the PTS for the correct FTM commands:
https://source.sierrawireless.com/resources/airprime/minicard/75xx/airprime_em7565_product_technical_specification/
read the “Production Testing” section
Thanks!! James!!
Thanks to your comments, I did some FTM test.
but, I still have two question.
  1. Is there anyway to test(check) network information of UMTS, LTE manually.
    e.g.> a. set band and specific channels
    b. find the network information (MCC, MNC, RSSI …)
    in both WCDMA and LTE
     In our application, to find the information of specific neighboring cells are very important.
  2. In FTM test, can I set the receiver frequency as other frequencies not in table?
    I tried to “RF receive path test of UMTS”.
    According to our base station, I put <channel number 10812>.
    But, Error occured.
Thanks in advance.
You really help me out!
Thanks!
Kevin
Hi Kevin,
  1. We don’t have FTM commands to get the NTWK info.
But you can use at!gstatus? in normal mode. At!lteinfo? will list the MCC/MNC
  1. ! DARCONFIG uses uplink (Tx) channel at the center of the corresponding band (rounded down), for both Tx and Rx testing). PTS page 83
So you have to use the UL channel for Tx and Rx testing.
James
Thanks~ James,
  1. I checked and used ‘at!lteinfo’ for lte network.
    But, I can’t find WCDMA network. (‘at!gstatus’ can’t show the mnc/mcc as long as i found.)
    and I think ‘at!lteinfo’ doesn’t show every lte networks in the band configured by ‘at!band’.
I am working for some application in which ALL neighboring network (WCDMA, LTE) information is very important.
  1. UPlink frequency. I will try!
Thanks~ again!
Kevin
Hi Kevin,
We don’t have AT commands to list the MCC/MNC in WCDMA mode. QMI interface has more NTWK related commands.
“I am working for some application in which ALL neighboring network (WCDMA, LTE) information is very important.”
Are you writing an application to search, list and select available cells/NTWKs?
I’d not do that. The modem is designed to find the best available NTWK.
James
