I am developing an application for the SL8084T to be used in Japan on the Docomo network. Therefore I would like to use the Docomo-approved firmware version S4.1.0.7D which I can get from the Sierra site as 3 cwe files.
On Windows, how can I update the firmware from these cwe files? Is there a special tool that I need to use?
If you have lots of modules that need updating to the latest firmware and you don’t have a one-click installer then it can very time consuming using Developer Studio to do it manually.
This semi-automated approach using the SW BinUpdater utility works for me on the SL8082T:
(1) Download a Windows executable installer for your module. I use “R7.52.2.A5.201411281219.SL808x exe” for the SL8082T
(2) Disconnect your modem from the PC
(3) Double-click the Windows executable. It will say “Unable to detect modem”. Close the application
(4) Copy this folder to your desktop or other location: “C:\Users[i]username[/i]\AppData\Local\Temp\BinUpdater”
(5) Copy your downloaded boot and firmware CWE files into this folder
(6) Run the update utility from the command line as follows:
