Hi Everybody.
Here is a Sample of DOTA with the WIP stack
Hope This is useful
I have placed alot of TRACES and comments in the code.
Please do not e-mail me for support on this code.
Ask your questions on this forum
Best regards
Walter
Created by Walter Senekal
walter@senekal.net
This code is provided Royalty free
and AS-IS
This code is only for evaluation purpose
and not for production.
PLEASE DO NOT E-MAIL FOR SUPPORT ON
THIS CODE.I WILL NOT ANSWER THEM
Please ask your questions on the FORUM
(I provided my e-mail if somebody
wants to discuss some bugs or suggestions on the code)
#include "adl_global.h"
#include "wip.h"
#if __OAT_API_VERSION__ = 400
const u16 wm_apmCustomStackSize = 4096;
#else
u32 wm_apmCustomStack[1024];
const u16 wm_apmCustomStackSize = sizeof(wm_apmCustomStack);
#endif
/* Variables */
u8 ftp_State = 0;
u8 GPRS_State = 0;
s32 DOTA_Cell_Handle = 0;
s32 ADEventHandle = 0;
ascii SimPin[4];
static wip_bearer_t gprs_bearer = NULL;
wip_channel_t ftp_WipHandle, ftp_Data_Channel;
ascii dotafile[64];
//TRACE LEVELS
#define lvl_Common 9
#define lvl_Sim 10
#define lvl_WIP 11
#define lvl_AD 12
// Destination address
#define STR_SIZE 64 // Common string size
#define STR_SIZE_SRV 128 // Server parameters string size
struct
u16 Port; // FTP server port
u8 Mode; // FTP server mode (active/passive)
ascii Type; // FTP server type (binary/ascii)
ascii Server[STR_SIZE_SRV]; // FTP server address
ascii Login[STR_SIZE]; // FTP account login
ascii Password[STR_SIZE]; // FTP account password
ascii FileName1[STR_SIZE_SRV]; // FTP server file name
ascii FileName2[STR_SIZE_SRV]; // FTP server file name
} ftp_DestAddr;
struct
ascii APN_Name[STR_SIZE];
ascii Username[STR_SIZE];
} APN_Details;
void adl_main(adl_InitType_e InitType);
void initvariables();
void Sim_Handler(u8 Event);
void GPRS_Attach();
static void gprs_bearer_handler(wip_bearer_t br, s8 event, void *ctx);
void ConnectFTP();
void ftp_SessionHandler(wip_event_t *ev, void *ctx);
void ftp_DataHandler(wip_event_t *ev, void *ctx);
//void ftp_Write(void);
void ftp_Read(void);
//void FTPGetMyFile(wip_event_t *ev, void *ctx);
void ADEvHandler(adl_adEvent_e Event, u32 Progress);
void DotaCellHandleReturnValue();
void CmdDOTAHandler1(adl_atCmdPreParser_t *params);
void CmdDOTAHandler2(adl_atCmdPreParser_t *params);
void CmdFORMATHandler(adl_atCmdPreParser_t *params);
void CmdINSTALLHandler(adl_atCmdPreParser_t *params);
void CmdCOMPACTHandler(adl_atCmdPreParser_t *params);
/* Local functions */
s8 S8RetVal = 0;
s32 s32RetVal = 0;
TRACE((lvl_Common, "adl_main :Start InitType: %d", InitType));
GPRS_State = 0;
//This Check is only for RTE because it does not always return the correct InitType
if (InitType < 0)
InitType = 0;
// Initialize TCP/IP stack
S8RetVal = wip_netInit();
TRACE((lvl_AD, "wip_netInit Ret= %d", S8RetVal));
// Initialize My Variables
initvariables();
//Subscribe To Sim card For Notifications
s32RetVal = adl_simSubscribe(Sim_Handler, SimPin);
TRACE((lvl_Sim, "adl_simSubscribe Ret= %d", s32RetVal));
//Subscribe To A&D Events
ADEventHandle = adl_adEventSubscribe(ADEvHandler);
TRACE((lvl_AD, "adl_adEventSubscribe Ret= %d", ADEventHandle));
adl_atCmdSubscribe("AT+DOTA1", CmdDOTAHandler1, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+DOTA2", CmdDOTAHandler2, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+FORMAT", CmdFORMATHandler, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+INSTALL", CmdINSTALLHandler, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+COMPACT", CmdCOMPACTHandler, ADL_CMD_TYPE_ACT);
adl_atSendResponse(ADL_AT_RSP, "\r\nApp Version:2\r\n");
switch (InitType)
case ADL_INIT_POWER_ON:
// Normal power on
TRACE((lvl_Common, "ADL_INIT_POWER_ON"));
adl_atSendResponse(ADL_AT_RSP, "\r\nApp Start Normally\r\n");
adl_atSendResponse(ADL_AT_RSP, "\r\nPlease Wait For Sim To Init...\r\n");
//Create a Cell For The Dota File
DOTA_Cell_Handle = adl_adSubscribe(0, ADL_AD_SIZE_UNDEF);
TRACE((lvl_AD, "DOTA_Cell_Subscribe Ret= %d", DOTA_Cell_Handle));
if (DOTA_Cell_Handle < 0)
//If Cell Is Not Subscribed WHY???
break;
case ADL_INIT_REBOOT_FROM_EXCEPTION:
// Reboot after an embedded application exception
TRACE((lvl_Common, "ADL_INIT_REBOOT_FROM_EXCEPTION"));
adl_atSendResponse(ADL_AT_RSP, "\r\nModem Start After Exception\r\n");
break;
case ADL_INIT_DOWNLOAD_SUCCESS:
// Reboot after a successful download process
TRACE((lvl_Common, "ADL_INIT_DOWNLOAD_SUCCESS"));
adl_atSendResponse(ADL_AT_RSP, "\r\nModem Start After DOTA OK\r\n");
//Format A&D to clear Dota File
s32RetVal = adl_adFormat(ADEventHandle);
TRACE((lvl_AD, "adl_adFormat Ret= %d", s32RetVal));
break;
case ADL_INIT_DOWNLOAD_ERROR:
// Reboot after a Failed download process
TRACE((lvl_Common, "ADL_INIT_DOWNLOAD_ERROR"));
adl_atSendResponse(ADL_AT_RSP, "\r\nModem Start After DOTA KO\r\n");
////s32RetVal = adl_adFormat(ADEventHandle);
////TRACE((lvl_AD, "adl_adFormat Ret= %d", s32RetVal));
break;
TRACE((lvl_Common, "adl_main :Exit"));
//TODO: Handle Cell Subscribe Failures
TRACE((lvl_AD, "DotaCellHandleReturnValue :Start"));
switch (DOTA_Cell_Handle)
case ADL_RET_ERR_ALREADY_SUBSCRIBED:
TRACE((lvl_AD, "ADL_RET_ERR_ALREADY_SUBSCRIBED"));
//if the cell is already subscribed
break;
case ADL_RET_ERR_PARAM:
//on parameter error
TRACE((lvl_AD, "ADL_RET_ERR_PARAM"));
break;
case ADL_RET_ERR_BAD_STATE:
//if an undefined size cell is already subscribed and not finalized
TRACE((lvl_AD, "ADL_RET_ERR_BAD_STATE"));
break;
case ADL_AD_RET_ERR_NOT_AVAILABLE:
//if A&D space is not available
TRACE((lvl_AD, "ADL_AD_RET_ERR_NOT_AVAILABLE"));
break;
case ADL_AD_RET_ERR_OVERFLOW:
//if there is not enough space for allocation
TRACE((lvl_AD, "ADL_AD_RET_ERR_OVERFLOW"));
break;
case ADL_RET_ERR_SERVICE_LOCKED:
//if called from a low level interruption handler
TRACE((lvl_AD, "ADL_RET_ERR_SERVICE_LOCKED"));
break;
TRACE((lvl_AD, "DotaCellHandleReturnValue :Exit"));
TRACE((lvl_AD, "ADEvHandler :Start Event: %d", Event));
switch (Event)
case ADL_AD_EVENT_FORMAT_INIT:
// Format process initialization
TRACE((lvl_AD, "ADL_AD_EVENT_FORMAT_INIT"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFormat Starting...\r\n");
break;
case ADL_AD_EVENT_FORMAT_PROGRESS:
// Format process progress
TRACE((lvl_AD, "ADL_AD_EVENT_FORMAT_PROGRESS"));
break;
case ADL_AD_EVENT_FORMAT_DONE:
// Format process Done
TRACE((lvl_AD, "ADL_AD_EVENT_FORMAT_DONE"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFormat Completed\r\n");
//A&D Is Empty Create your A&D objects
//NOTE! if you create undefined size then you can only create one
TRACE((lvl_AD, "DOTA_Cell_Handle=%d", DOTA_Cell_Handle));
break;
case ADL_AD_EVENT_RECOMPACT_INIT:
// Re-compaction process initialization
TRACE((lvl_AD, "ADL_AD_EVENT_RECOMPACT_INIT"));
adl_atSendResponse(ADL_AT_RSP, "\r\nRecompact Starting...\r\n");
break;
case ADL_AD_EVENT_RECOMPACT_PROGRESS:
// Re-compaction process progress
TRACE((lvl_AD, "ADL_AD_EVENT_RECOMPACT_PROGRESS"));
break;
case ADL_AD_EVENT_RECOMPACT_DONE:
// Re-compaction process Done
TRACE((lvl_AD, "ADL_AD_EVENT_RECOMPACT_DONE"));
adl_atSendResponse(ADL_AT_RSP, "\r\nRecompact Completed\r\n");
break;
case ADL_AD_EVENT_INSTALL:
TRACE((lvl_AD, "ADL_AD_EVENT_INSTALL"));
adl_atSendResponse(ADL_AT_RSP, "\r\nInstall AD\r\n");
break;
TRACE((lvl_AD, "ADEvHandler :Exit"));
TRACE((lvl_Sim, "Sim_Handler :Start with Event: %d", Event));
switch (Event)
case ADL_SIM_EVENT_FULL_INIT:
//When Sim is fully Init then Continue
adl_atSendResponse(ADL_AT_RSP, "\r\nSim Init Complete\r\n");
GPRS_Attach();
break;
case ADL_SIM_EVENT_PIN_WAIT:
TRACE((lvl_Sim, "ADL_SIM_EVENT_PIN_WAIT"));
break;
case ADL_SIM_EVENT_PIN_OK:
TRACE((lvl_Sim, "ADL_SIM_EVENT_PIN_OK"));
break;
case ADL_SIM_EVENT_INSERTED:
TRACE((lvl_Sim, "ADL_SIM_EVENT_INSERTED"));
break;
case ADL_SIM_EVENT_REMOVED:
TRACE((lvl_Sim, "ADL_SIM_EVENT_REMOVED"));
break;
case ADL_SIM_EVENT_PIN_ERROR:
TRACE((lvl_Sim, "ADL_SIM_EVENT_PIN_ERROR"));
break;
case ADL_SIM_EVENT_PIN_NO_ATTEMPT:
TRACE((lvl_Sim, "ADL_SIM_EVENT_PIN_NO_ATTEMPT"));
break;
case ADL_SIM_EVENT_LAST:
TRACE((lvl_Sim, "ADL_SIM_EVENT_LAST"));
break;
TRACE((lvl_Sim, "Sim_Handler :Exit"));
void GPRS_Attach()
s8 s8RetVal;
TRACE((lvl_WIP, "GPRS_Attach :Start"));
adl_atSendResponse(ADL_AT_RSP, "\r\nConnectiong To GPRS...\r\n");
//Create a Bearer e.g GPRS,CSD Call,UART
s8RetVal = wip_bearerOpen(&gprs_bearer, "GPRS", gprs_bearer_handler, NULL);
TRACE((lvl_WIP, "wip_bearerOpen Retval: %d", s8RetVal));
//Provide GPRS(in this case)Login Details
s8RetVal = wip_bearerSetOpts(gprs_bearer, WIP_BOPT_GPRS_APN,
APN_Details.APN_Name, WIP_BOPT_LOGIN, APN_Details.Username,
WIP_BOPT_PASSWORD, APN_Details.Password, WIP_BOPT_END);
TRACE((lvl_WIP, "wip_bearerSetOpts Retval: %d", s8RetVal));
//Connect the Bearer(GPRS Attach)
s8RetVal = wip_bearerStart(gprs_bearer);
TRACE((lvl_WIP, "wip_bearerStart Retval: %d", s8RetVal));
TRACE((lvl_WIP, "GPRS_Attach :Exit"));
ascii RspStr[128];
ascii ipStr[16], dns1Str[16], dns2Str[16];
wip_in_addr_t ip, dns1, dns2;
TRACE((lvl_WIP, "gprs_bearer_handler :Start with Event: %d", event));
//Make Sure Correct Bearer is connecting
if (br != gprs_bearer)
return ;
switch (event)
case WIP_BEV_IP_CONNECTED:
//Get Bearer Info
TRACE((lvl_WIP, "WIP_BEV_IP_CONNECTED"));
wip_bearerGetOpts(br, WIP_BOPT_IP_ADDR, &ip, WIP_BOPT_IP_DNS1, &dns1,
WIP_BOPT_IP_DNS2, &dns2, WIP_BOPT_END);
wip_inet_ntoa(ip, ipStr, sizeof(ipStr));
wip_inet_ntoa(dns1, dns1Str, sizeof(dns1Str));
wip_inet_ntoa(dns2, dns2Str, sizeof(dns2Str));
wm_sprintf(RspStr, "\r\nGPRS: CONNECTED IP=%s DNS1=%s DNS2=%s\r\n", ipStr,
dns1Str, dns2Str);
TRACE((lvl_WIP, RspStr));
adl_atSendResponse(ADL_AT_UNS, RspStr);
adl_atSendResponse(ADL_AT_RSP, "\r\nGPRS Connect Ready For DOTA\r\n");
GPRS_State = 1;
break;
case WIP_BEV_IP_DISCONNECTED:
TRACE((lvl_WIP, "WIP_BEV_IP_DISCONNECTED"));
adl_atSendResponse(ADL_AT_UNS, "\r\n+WIPSTART: DISCONNECTED\r\n");
GPRS_State = 0;
//ReAttach
GPRS_Attach();
break;
case WIP_BEV_STOPPED:
TRACE((lvl_WIP, "WIP_BEV_STOPPED"));
wip_bearerClose(br);
GPRS_State = 0;
gprs_bearer = NULL;
//ReAttach
GPRS_Attach();
break;
case WIP_BEV_CONN_FAILED:
TRACE((lvl_WIP, "WIP_BEV_CONN_FAILED"));
adl_atSendResponse(ADL_AT_UNS, "\r\n+WIPSTART: FAILED\r\n");
gprs_bearer = NULL;
//ReAttach
GPRS_State = 0;
GPRS_Attach();
break;
TRACE((lvl_WIP, "gprs_bearer_handler :Exit"));
void ConnectFTP()
TRACE((lvl_WIP, "ConnectFTP :Start"));
// Check for current state
if (!ftp_State)
// Get parameters
s8 sReturn = OK;
//ftp_Mode = FTP_MODE_GET;
// adl_atSendResponse( ADL_AT_RSP,"\r\nEnter ConnectFTP\r\n");
ftp_WipHandle = wip_FTPCreateOpts(ftp_DestAddr.Server, ftp_SessionHandler,
NULL, WIP_COPT_USER, ftp_DestAddr.Login, WIP_COPT_PASSWORD,
ftp_DestAddr.Password, WIP_COPT_PASSIVE, ftp_DestAddr.Mode, WIP_COPT_TYPE,
ftp_DestAddr.Type, WIP_COPT_PEER_PORT, ftp_DestAddr.Port, WIP_COPT_END);
if (ftp_WipHandle == NULL)
// FTP error
TRACE((lvl_WIP, "FTP Has Not Started"));
adl_atSendStdResponseExt(ADL_AT_RSP, ADL_STR_CME_ERROR, 3);
ftp_State = 0;
else
// FTP started
TRACE((lvl_WIP, "FTP Has Started Ok"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFTP STARTED OK\r\n");
ftp_State = 1;
else
// Already running
adl_atSendStdResponseExt(ADL_AT_RSP, ADL_STR_CME_ERROR, 515);
TRACE((lvl_WIP, "ConnectFTP :Exit"));
TRACE((lvl_WIP, "ftp_SessionHandler :Start with Event %d", ev->kind));
switch (ev->kind)
case WIP_CEV_OPEN:
//Download The Dota File
//TODO Make sure Cell is empty first
TRACE((lvl_WIP, "WIP_CEV_OPEN"));
adl_atSendResponse(ADL_AT_RSP, "\r\nDownloading New App\r\n");
ftp_Data_Channel = wip_getFile(ftp_WipHandle, dotafile, ftp_DataHandler,
NULL);
break;
case WIP_CEV_DONE:
//Called if you close the Connection
TRACE((lvl_WIP, "WIP_CEV_DONE"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFTP Connection Closed by APP\r\n");
break;
case WIP_CEV_PEER_CLOSE:
//Called if Remote Connection Closes the Connection
TRACE((lvl_WIP, "WIP_CEV_PEER_CLOSE"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFTP Connection Closed by PEER\r\n");
case WIP_CEV_ERROR:
// End of transfer
TRACE((lvl_WIP, "WIP_CEV_ERROR"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFTP Connection Closed \r\n");
ftp_State = 0;
//Close the FTP Connection
wip_close(ftp_WipHandle);
ftp_WipHandle = NULL;
break;
TRACE((lvl_WIP, "ftp_SessionHandler :Exit"));
s32 s32RetVal = 0;
TRACE((lvl_WIP, "ftp_DataHandler :Start with Event %d", ev->kind));
wip_debug("FTP data event: %d\n", ev->kind);
switch (ev->kind)
case WIP_CEV_OPEN:
break;
case WIP_CEV_READ:
TRACE((lvl_WIP, "WIP_CEV_READ"));
// Read FTP data
adl_atSendResponse(ADL_AT_RSP, "$");
ftp_Read();
break;
case WIP_CEV_WRITE:
TRACE((lvl_WIP, "WIP_CEV_WRITE"));
// Write FTP Data
break;
//all Data Downloaded
adl_atSendResponse(ADL_AT_RSP, "\r\nFTP Download Completed\r\n");
//Finalize Cell with Undefined Size before you can use it
s32RetVal = adl_adFinalise(DOTA_Cell_Handle);
TRACE((lvl_WIP, "adl_adFinalise return Code %d", s32RetVal));
case WIP_CEV_ERROR:
// Close data channel
wip_close(ftp_Data_Channel);
// Close session channel
TRACE((lvl_WIP, "ErrorNumber: %d", ev->content.error.errnum));
if (ev->content.error.errnum == WIP_CERR_ABORTED)
TRACE((1, "ftp download aborted"));
adl_atSendResponse(ADL_AT_RSP, "\r\nFTP Download Aborted\r\n");
if (ftp_WipHandle != NULL)
break;
TRACE((lvl_WIP, "ftp_DataHandler :Exit"));
void ftp_Read(void)
int len = 0x00;
u8 buf[256] =
NULL
s32 RetVal32 = 0x00;
TRACE((lvl_WIP, "ftp_Read :Start"));
TRACE((1, "Read Data From FTP"));
//Keep reading until you read 0
while ((len = wip_read(ftp_Data_Channel, buf, sizeof(buf))) > 0)
//Write Data To A&D
TRACE((lvl_WIP, "Bytes Read:%d", len));
//New Data is added to end of Current data in Cell
RetVal32 = adl_adWrite(DOTA_Cell_Handle, len, (void*)buf);
TRACE((lvl_WIP, "adl_adWrite RetCode:%d", RetVal32));
if (RetVal32 != 0)
"\r\nSomething is wrong with A&D Space,\r\nPlease format and Retry\r\n")
TRACE((lvl_WIP, "ftp_Read :Exit"));
TRACE((lvl_Common, "CmdDOTAHandler1 :Start With Event %d", params->Type));
if (GPRS_State == 1)
//Connect To FTP To Download New Application
wm_sprintf(dotafile, ftp_DestAddr.FileName1);
adl_atSendResponse(ADL_AT_RSP, "\r\nOK\r\n");
ConnectFTP();
else
//Connect To GPRS First
adl_atSendResponse(ADL_AT_RSP, "\r\nFirst Connecting to GPRS\r\n");
adl_atSendResponse(ADL_AT_RSP, "Please Wait Before Retry\r\n");
adl_atSendResponse(ADL_AT_RSP, "Error\r\n");
GPRS_Attach();
TRACE((lvl_Common, "CmdDOTAHandler1 :Exit"));
TRACE((lvl_Common, "CmdDOTAHandler2 :Start With Event %d", params->Type));
wm_sprintf(dotafile, ftp_DestAddr.FileName2);
ConnectFTP();
else
GPRS_Attach();
TRACE((lvl_Common, "CmdDOTAHandler2 :Exit"));
s32 s32RetVal;
TRACE((lvl_Common, "CmdFORMATHandler :Start With Event %d", params->Type));
adl_adUnsubscribe(DOTA_Cell_Handle);
if (s32RetVal == 0)
else
adl_atSendResponse(ADL_AT_RSP, "Error");
// OK */
//ADL_RET_ERR_UNKNOWN_HDL //if the handle is unknown */
//ADL_RET_ERR_NOT_SUBSCRIBED //if the service is not subscribed*/
//ADL_AD_RET_ERR_NOT_AVAILABLE //if A&D space is not available */
//ADL_RET_ERR_BAD_STATE //if there is at least one currently */
//subscribed cell or if a recompact/format process is running */
//ADL_RET_ERR_SERVICE_LOCKED //if called from a low level
TRACE((lvl_Common, "CmdFORMATHandler :Exit"));
s32 s32RetVal;
TRACE((lvl_Common, "CmdINSTALLHandler :Start With Event %d", params->Type));
//Install The New Application
s32RetVal = adl_adInstall(DOTA_Cell_Handle);
if (s32RetVal != OK)
else
adl_atSendResponse(ADL_AT_RSP, "OK\r\n");
TRACE((lvl_Common, "CmdINSTALLHandler :Exit"));
s32 s32RetVal;
TRACE((lvl_Common, "CmdCOMPACTHandler :Start With Event %d", params->Type));
s32RetVal = adl_adRecompact(ADEventHandle);
TRACE((lvl_AD, "adl_adRecompact Ret= %d", s32RetVal));
if (s32RetVal == 0)
else
TRACE((lvl_Common, "CmdCOMPACTHandler :Exit"));
TRACE((lvl_WIP, "initvariables :Start"));
ftp_DestAddr.Port = 21;
ftp_DestAddr.Mode = 1;
ftp_DestAddr.Type = 'A';
wm_sprintf(ftp_DestAddr.Server, "your.own.ftp.server");
wm_sprintf(ftp_DestAddr.Login, "UserName");
wm_sprintf(ftp_DestAddr.Password, "Password");
wm_sprintf(ftp_DestAddr.FileName1, "file1.wpb.dwl");
wm_sprintf(ftp_DestAddr.FileName2, "file2.dwl");
wm_sprintf(APN_Details.APN_Name, "APN_Name");
wm_sprintf(APN_Details.Username, "APN_username");
wm_sprintf(APN_Details.Password, "APN_password");
TRACE((lvl_WIP, "initvariables :Exit"));
