Good morning everyone!
The fisrt, i want saying thanks you to everyone reading my Topic and try to help me. Thanks you very much.
Now i’ve problem with DOTA. This is My Sample code :
#include "adl_global.h"
#include "wip.h"
const u16 wm_apmCustomStackSize = 4096;
/* Variables */
u8 ftp_State = 0;
u8 GPRS_State = 0;
s32 DOTA_Cell_Handle = 0;
s32 ADEventHandle = 0;
ascii SimPin[4];
static wip_bearer_t gprs_bearer = NULL;
wip_channel_t ftp_WipHandle, ftp_Data_Channel;
ascii dotafile[64];
wip_bearer_t myBearer;
//TRACE LEVELS
#define lvl_Common 9
#define lvl_Sim 10
#define lvl_WIP 11
#define lvl_AD 12
// Destination address
#define STR_SIZE 64 // Common string size
#define STR_SIZE_SRV 128 // Server parameters string size
struct
u16 Port; // FTP server port
u8 Mode; // FTP server mode (active/passive)
ascii Type; // FTP server type (binary/ascii)
ascii Server[STR_SIZE_SRV]; // FTP server address
ascii Login[STR_SIZE]; // FTP account login
ascii Password[STR_SIZE]; // FTP account password
ascii FileName1[STR_SIZE_SRV]; // FTP server file name
ascii FileName2[STR_SIZE_SRV]; // FTP server file name
} ftp_DestAddr;
struct
ascii APN_Name[STR_SIZE];
ascii Username[STR_SIZE];
} APN_Details;
void adl_main(adl_InitType_e InitType);
void initvariables();
void Sim_Handler(u8 Event);
void GPRS_Attach(wip_bearer_t *wb);
static void gprs_bearer_handler(wip_bearer_t br, s8 event, void *ctx);
void ConnectFTP();
void ftp_SessionHandler(wip_event_t *ev, void *ctx);
void ftp_DataHandler(wip_event_t *ev, void *ctx);
//void ftp_Write(void);
void ftp_Read(void);
//void FTPGetMyFile(wip_event_t *ev, void *ctx);
void ADEvHandler(adl_adEvent_e Event, u32 Progress);
void DotaCellHandleReturnValue();
void CmdDOTAHandler1(adl_atCmdPreParser_t *params);
void CmdDOTAHandler2(adl_atCmdPreParser_t *params);
void CmdFORMATHandler(adl_atCmdPreParser_t *params);
void CmdINSTALLHandler(adl_atCmdPreParser_t *params);
void CmdCOMPACTHandler(adl_atCmdPreParser_t *params);
/* Local functions */
char ErrMsg[256];
void mlog(ascii *msg)
adl_atSendResponse(ADL_AT_PORT_TYPE(ADL_PORT_UART1,ADL_AT_RSP), msg);
char InfoMsg[256];
void Info(ascii *msg)
s8 S8RetVal = 0;
s32 s32RetVal = 0;
wm_sprintf(InfoMsg, "adl_main :Start InitType: %d\r\n", InitType);
Info(InfoMsg);
GPRS_State = 0;
//This Check is only for RTE because it does not always return the correct InitType
if (InitType < 0)
InitType = 0;
// Initialize TCP/IP stack
S8RetVal = wip_netInit();
wm_sprintf(InfoMsg, "wip_netInit Ret= %d\r\n", S8RetVal);
Info(InfoMsg);
// Initialize My Variables
initvariables();
//Subscribe To Sim card For Notifications
s32RetVal = adl_simSubscribe(Sim_Handler, SimPin);
wm_sprintf(InfoMsg, "adl_simSubscribe Ret= %d\r\n", s32RetVal);
Info(InfoMsg);
ADEventHandle = adl_adEventSubscribe(ADEvHandler);
wm_sprintf(InfoMsg, "adl_adEventSubscribe Ret= %d\r\n", ADEventHandle);
Info(InfoMsg);
adl_atCmdSubscribe("AT+DOTA1", CmdDOTAHandler1, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+DOTA2", CmdDOTAHandler2, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+FORMAT", CmdFORMATHandler, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+INSTALL", CmdINSTALLHandler, ADL_CMD_TYPE_ACT);
adl_atCmdSubscribe("AT+COMPACT", CmdCOMPACTHandler, ADL_CMD_TYPE_ACT);
wm_sprintf(InfoMsg, "App Version : 2\r\n");
Info(InfoMsg);
switch (InitType)
case ADL_INIT_POWER_ON:
// Normal power on
wm_sprintf(InfoMsg, "ADL_INIT_POWER_ON\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "app start normallY\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Please wait for Sim to Init...\r\n" );
Info(InfoMsg);
//Create a Cell For The Dota File
DOTA_Cell_Handle = adl_adSubscribe(0, ADL_AD_SIZE_UNDEF);
wm_sprintf(InfoMsg, "DOTA_Cell_Subscribe Ret= %d\r\n", DOTA_Cell_Handle);
Info(InfoMsg);
if (DOTA_Cell_Handle < 0)
//If Cell Is Not Subscribed WHY???
break;
case ADL_INIT_REBOOT_FROM_EXCEPTION:
// Reboot after an embedded application exception
wm_sprintf(InfoMsg, "ADL_INIT_REBOOT_FROM_EXCEPTION\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Modem Start After Exception\r\n" );
Info(InfoMsg);
break;
case ADL_INIT_DOWNLOAD_SUCCESS:
// Reboot after a successful download process
wm_sprintf(InfoMsg, "ADL_INIT_DOWNLOAD SUCCESS\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "MODEM START AFTER DOTA OK\r\n" );
Info(InfoMsg);
//Format A&D to clear Dota File
s32RetVal = adl_adFormat(ADEventHandle);
wm_sprintf(InfoMsg, "adl_adFormat Ret= %d\r\n", s32RetVal);
Info(InfoMsg);
break;
case ADL_INIT_DOWNLOAD_ERROR:
// Reboot after a Failed download process
wm_sprintf(InfoMsg, "ADL_INIT_DOWNLOAD_ERROR\r\n" );
Info(InfoMsg);
Info(InfoMsg);
////s32RetVal = adl_adFormat(ADEventHandle);
////TRACE((lvl_AD, "adl_adFormat Ret= %d", s32RetVal));
break;
wm_sprintf(InfoMsg, "EXIT MAIN.\r\n" );
Info(InfoMsg);
//TODO: Handle Cell Subscribe Failures
wm_sprintf(InfoMsg, "DotaCellHandleReturnValue :Start\r\n" );
Info(InfoMsg);
switch (DOTA_Cell_Handle)
case ADL_RET_ERR_ALREADY_SUBSCRIBED:
wm_sprintf(InfoMsg, "ADL_RET_ERR_ALREADY_SUBSCRIBED\r\n" );
Info(InfoMsg);
//if the cell is already subscribed
break;
case ADL_RET_ERR_PARAM:
//on parameter error
wm_sprintf(InfoMsg, "ADL_RET_ERR_PARAM\r\n" );
Info(InfoMsg);
break;
case ADL_RET_ERR_BAD_STATE:
//if an undefined size cell is already subscribed and not finalized
wm_sprintf(InfoMsg, "ADL_RET_ERR_BAD_STATE\r\n" );
Info(InfoMsg);
break;
case ADL_AD_RET_ERR_NOT_AVAILABLE:
//if A&D space is not available
wm_sprintf(InfoMsg, "ADL_AD_RET_ERR_NOT_AVAILABLE\r\n" );
Info(InfoMsg);
break;
case ADL_AD_RET_ERR_OVERFLOW:
//if there is not enough space for allocation
wm_sprintf(InfoMsg, "ADL_AD_RET_ERR_OVERFLOW\r\n" );
Info(InfoMsg);
break;
case ADL_RET_ERR_SERVICE_LOCKED:
//if called from a low level interruption handler
wm_sprintf(InfoMsg, "ADL_RET_ERR_SERVICE_LOCKED\r\n" );
Info(InfoMsg);
break;
wm_sprintf(InfoMsg, "DotaCellHandleReturnValue :Exit\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "ADEvHandler :Start Event: %d\r\n",Event );
Info(InfoMsg);
switch (Event)
case ADL_AD_EVENT_FORMAT_INIT:
// Format process initialization
wm_sprintf(InfoMsg, "ADL_AD_EVENT_FORMAT_INIT.....\r\n" );
Info(InfoMsg);
break;
case ADL_AD_EVENT_FORMAT_PROGRESS:
// Format process progress
wm_sprintf(InfoMsg, "ADL_AD_EVENT_FORMAT_PROGRESS\r\n" );
Info(InfoMsg);
break;
case ADL_AD_EVENT_FORMAT_DONE:
// Format process Done
wm_sprintf(InfoMsg, "ADL_AD_EVENT_FORMAT_DONE...FORMAT COMPLETED\r\n" );
Info(InfoMsg);
//A&D Is Empty Create your A&D objects
//NOTE! if you create undefined size then you can only create one
wm_sprintf(InfoMsg, "DOTA CELL HANDLE =: %d\r\n",DOTA_Cell_Handle );
Info(InfoMsg);
break;
case ADL_AD_EVENT_RECOMPACT_INIT:
// Re-compaction process initialization
wm_sprintf(InfoMsg, "ADL_AD_EVENT_RECOMPACT_INIT\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Recompact Starting...\r\n" );
Info(InfoMsg);
break;
case ADL_AD_EVENT_RECOMPACT_PROGRESS:
// Re-compaction process progress
wm_sprintf(InfoMsg, "ADL_AD_EVENT_RECOMPACT_PROGRESS\r\n" );
Info(InfoMsg);
break;
case ADL_AD_EVENT_RECOMPACT_DONE:
// Re-compaction process Done
wm_sprintf(InfoMsg,"ADL_AD_EVENT_RECOMPACT_DONE \r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg,"Recompact Completed\r\n");
Info(InfoMsg);
wm_sprintf(InfoMsg, "DOTA_Cell_Handle=%d\r\n", DOTA_Cell_Handle );
Info(InfoMsg);
if (DOTA_Cell_Handle <0)
break;
case ADL_AD_EVENT_INSTALL:
wm_sprintf(InfoMsg,"ADL_AD_EVENT_INSTALL \r\n" );
Info(InfoMsg);
break;
wm_sprintf(InfoMsg,"ADEvHandler :Exit \r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Sim_Handler :Start with Event: %d\r\n", Event );
Info(InfoMsg);
switch (Event)
case ADL_SIM_EVENT_FULL_INIT:
//When Sim is fully Init then Continue
wm_sprintf(InfoMsg,"Sim Init Complete \r\n" );
Info(InfoMsg);
GPRS_Attach(&myBearer);
break;
case ADL_SIM_EVENT_PIN_WAIT:
wm_sprintf(InfoMsg, "ADL_SIM_EVENT_PIN_WAIT\r\n" );
Info(InfoMsg);
break;
case ADL_SIM_EVENT_PIN_OK:
wm_sprintf(InfoMsg, "ADL_SIM_EVENT_PIN_OK\r\n" );
Info(InfoMsg);
break;
case ADL_SIM_EVENT_INSERTED:
wm_sprintf(InfoMsg,"ADL_SIM_EVENT_INSERTED \r\n" );
Info(InfoMsg);
break;
case ADL_SIM_EVENT_REMOVED:
wm_sprintf(InfoMsg, "ADL_SIM_EVENT_REMOVED\r\n" );
Info(InfoMsg);
break;
case ADL_SIM_EVENT_PIN_ERROR:
wm_sprintf(InfoMsg,"ADL_SIM_EVENT_PIN_ERROR \r\n" );
Info(InfoMsg);
break;
case ADL_SIM_EVENT_PIN_NO_ATTEMPT:
wm_sprintf(InfoMsg, "ADL_SIM_EVENT_PIN_NO_ATTEMPT\r\n" );
Info(InfoMsg);
break;
case ADL_SIM_EVENT_LAST:
wm_sprintf(InfoMsg, "ADL_SIM_EVENT_LAST \r\n" );
Info(InfoMsg);
break;
wm_sprintf(InfoMsg,"Sim_Handler :Exit \r\n" );
Info(InfoMsg);
s8 ercode;
s8 s8RetVal;
wm_sprintf(InfoMsg, "GPRS_Attach :Start\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg,"Connecting To GPRS... \r\n" );
Info(InfoMsg);
//Create a Bearer e.g GPRS,CSD Call,UART
s8RetVal = wip_bearerOpen(&gprs_bearer, "GPRS", gprs_bearer_handler, NULL);
wm_sprintf(InfoMsg,"wip_bearerOpen Retval: %d \r\n", s8RetVal );
Info(InfoMsg);
//Provide GPRS(in this case)Login Details
s8RetVal = wip_bearerSetOpts(gprs_bearer, WIP_BOPT_GPRS_APN,
APN_Details.APN_Name, WIP_BOPT_LOGIN, APN_Details.Username,
WIP_BOPT_PASSWORD, APN_Details.Password, WIP_BOPT_END);
wm_sprintf(InfoMsg,"wip_bearerSetOpts Retval: %d \r\n", s8RetVal );
Info(InfoMsg);
//Connect the Bearer(GPRS Attach)
s8RetVal = wip_bearerStart(gprs_bearer);
wm_sprintf(InfoMsg, "wip_bearerStart Retval: %d\r\n", s8RetVal );
Info(InfoMsg);
wm_sprintf(InfoMsg,"GPRS_Attach :Exit \r\n" );
Info(InfoMsg);
ascii RspStr[128];
ascii ipStr[16], dns1Str[16], dns2Str[16];
wip_in_addr_t ip, dns1, dns2;
wm_sprintf(InfoMsg,"gprs_bearer_handler :Start with Event: %d\r\n", event );
Info(InfoMsg);
//Make Sure Correct Bearer is connecting
if (br != gprs_bearer)
return ;
switch (event)
case WIP_BEV_IP_CONNECTED:
//Get Bearer Info
wm_sprintf(InfoMsg, "WIP_BEV_IP_CONNECTED\r\n" );
Info(InfoMsg);
wip_bearerGetOpts(br, WIP_BOPT_IP_ADDR,&ip, WIP_BOPT_IP_DNS1, &dns1,
WIP_BOPT_IP_DNS2,&dns2, WIP_BOPT_END);
wip_inet_ntoa(ip, ipStr, sizeof(ipStr));
wip_inet_ntoa(dns1, dns1Str, sizeof(dns1Str));
wip_inet_ntoa(dns2, dns2Str, sizeof(dns2Str));
wm_sprintf(InfoMsg, "GPRS: CONNECTED IP=%s DNS1=%s DNS2=%s\r\n", ipStr,dns1Str, dns2Str );
Info(InfoMsg);
wm_sprintf(InfoMsg, "%d\r\n" ,RspStr);
Info(InfoMsg);
wm_sprintf(InfoMsg, "GPRS Connect Ready For DOTA\r\n" );
Info(InfoMsg);
GPRS_State = 1;
break;
case WIP_BEV_IP_DISCONNECTED:
wm_sprintf(InfoMsg, "WIP_BEV_IP_DISCONNECTED\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg,"WIPSTART: DISCONNECTED \r\n" );
Info(InfoMsg);
GPRS_State = 0;
//ReAttach
break;
case WIP_BEV_STOPPED:
wm_sprintf(InfoMsg,"WIP_BEV_STOPPED \r\n" );
Info(InfoMsg);
wip_bearerClose(br);
GPRS_State = 0;
gprs_bearer = NULL;
//ReAttach
break;
case WIP_BEV_CONN_FAILED:
wm_sprintf(InfoMsg, "WIP_BEV_CONN_FAILED\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg,"WIPSTART: FAILED \r\n" );
Info(InfoMsg);
gprs_bearer = NULL;
//ReAttach
GPRS_State = 0;
break;
wm_sprintf(InfoMsg,"gprs_bearer_handler :Exit \r\n" );
Info(InfoMsg);
void ConnectFTP()
wm_sprintf(InfoMsg, "ConnectFTP :Start\r\n" );
Info(InfoMsg);
// Check for current state
if (!ftp_State)
// Get parameters
//ftp_Mode = FTP_MODE_GET;
// adl_atSendResponse( ADL_AT_RSP,"\r\nEnter ConnectFTP\r\n");
wm_sprintf(InfoMsg, "ConnectFTP :Start-> !ftp_State\r\n" );
Info(InfoMsg);
ftp_WipHandle = wip_FTPCreateOpts(ftp_DestAddr.Server, ftp_SessionHandler,
NULL, WIP_COPT_USER, ftp_DestAddr.Login, WIP_COPT_PASSWORD,
ftp_DestAddr.Password, WIP_COPT_PASSIVE, ftp_DestAddr.Mode, WIP_COPT_TYPE,
ftp_DestAddr.Type, WIP_COPT_PEER_PORT, ftp_DestAddr.Port, WIP_COPT_END);
if (ftp_WipHandle == NULL)
// FTP error
wm_sprintf(InfoMsg, "FTP Has Not Started\r\n" );
Info(InfoMsg);
adl_atSendStdResponseExt(ADL_AT_RSP, ADL_STR_CME_ERROR, 3);
ftp_State = 0;
else
// FTP started
wm_sprintf(InfoMsg, "FTP Has Started Ok%\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "FTP STARTED OK\r\n" );
Info(InfoMsg);
ftp_State = 1;
else
// Already running
adl_atSendStdResponseExt(ADL_AT_RSP, ADL_STR_CME_ERROR, 515);
wm_sprintf(InfoMsg, "ConnectFTP :Exit\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "ftp_SessionHandler :Start with Event %d\r\n", ev->kind );
Info(InfoMsg);
switch (ev->kind)
case WIP_CEV_OPEN:
//Download The Dota File
//TODO Make sure Cell is empty first
wm_sprintf(InfoMsg, "WIP_CEV_OPEN\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "DOWNLOADING NEW APP\r\n" );
Info(InfoMsg);
ftp_Data_Channel = wip_getFile(ftp_WipHandle, dotafile, ftp_DataHandler,NULL);
break;
case WIP_CEV_DONE:
//Called if you close the Connection
wm_sprintf(InfoMsg, "WIP_CEV_DONE\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "FTP CONNECTION CLOSED BY APP\r\n" );
Info(InfoMsg);
break;
case WIP_CEV_PEER_CLOSE:
//Called if Remote Connection Closes the Connection
wm_sprintf(InfoMsg, "WIP_CEV_PEER_CLOSE\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "FTP Connection Closed by PEER\r\n" );
Info(InfoMsg);
case WIP_CEV_ERROR:
// End of transfer
wm_sprintf(InfoMsg, "WIP_CEV_ERROR\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "FTP CONNECTION CLOSED\r\n" );
Info(InfoMsg);
ftp_State = 0;
//Close the FTP Connection
wip_close(ftp_WipHandle);
ftp_WipHandle = NULL;
break;
wm_sprintf(InfoMsg, "ftp_SessionHandler :Exit\r\n" );
Info(InfoMsg);
s32 s32RetVal = 0;
wm_sprintf(InfoMsg, "ftp_DataHandler :Start with Event %d\r\n", ev->kind );
Info(InfoMsg);
wip_debug("FTP data event: %d\n", ev->kind);
switch (ev->kind)
case WIP_CEV_OPEN:
Info(InfoMsg);
break;
case WIP_CEV_READ:
wm_sprintf(InfoMsg, "WIP_CEV_READ\r\n" );
Info(InfoMsg);
// Read FTP data
wm_sprintf(InfoMsg, "$\r\n" );
Info(InfoMsg);
ftp_Read();
break;
case WIP_CEV_WRITE:
wm_sprintf(InfoMsg, "WIP_CEV_WRITE\r\n" );
Info(InfoMsg);
// Write FTP Data
break;
Info(InfoMsg);
//all Data Downloaded
wm_sprintf(InfoMsg, "FTP Download Completed\r\n" );
Info(InfoMsg);
//Finalize Cell with Undefined Size before you can use it
s32RetVal = adl_adFinalise(DOTA_Cell_Handle);
wm_sprintf(InfoMsg,"adl_adFinalise return Code %d\r\n", s32RetVal );
Info(InfoMsg);
case WIP_CEV_ERROR:
Info(InfoMsg);
// Close data channel
wip_close(ftp_Data_Channel);
// Close session channel
wm_sprintf(InfoMsg, "ErrorNumber: %d\r\n", ev->content.error.errnum );
Info(InfoMsg);
if (ev->content.error.errnum == WIP_CERR_ABORTED)
wm_sprintf(InfoMsg, "ftp download aborted\r\n" );
Info(InfoMsg);
if (ftp_WipHandle != NULL)
break;
wm_sprintf(InfoMsg, "ftp_DataHandler :Exit\r\n" );
Info(InfoMsg);
void ftp_Read(void)
int len = 0x00;
u8 buf[256] =
NULL
s32 RetVal32 = 0x00;
wm_sprintf(InfoMsg, "ftp_Read :Start\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Read Data From FTP\r\n" );
Info(InfoMsg);
//Keep reading until you read 0
while ((len = wip_read(ftp_Data_Channel, buf, sizeof(buf))) > 0)
//Write Data To A&D
wm_sprintf(InfoMsg, "Bytes Read:%d\r\n", len );
Info(InfoMsg);
//New Data is added to end of Current data in Cell
RetVal32 = adl_adWrite(DOTA_Cell_Handle, len, (void*)buf);
wm_sprintf(InfoMsg, "adl_adWrite RetCode:%d\r\n", RetVal32 );
Info(InfoMsg);
if (RetVal32 != 0)
wm_sprintf(InfoMsg, "Something is wrong with A&D Space,\r\nPlease format and Retry\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "ftp_Read :Exit\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "CmdDOTAHandler1 :Start With Event %d\r\n", params->Type );
Info(InfoMsg);
if (GPRS_State == 1)
//Connect To FTP To Download New Application
wm_sprintf(dotafile, ftp_DestAddr.FileName1);
wm_sprintf(InfoMsg, "%s -> OK\r\n",dotafile );
Info(InfoMsg);
ConnectFTP();
else
//Connect To GPRS First
wm_sprintf(InfoMsg, "First Connecting to GPRS\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Please Wait Before Retry\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "Error\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "CmdDOTAHandler1 :Exit\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "CmdDOTAHandler2 :Start With Event %d\r\n" , params->Type);
Info(InfoMsg);
wm_sprintf(dotafile, ftp_DestAddr.FileName2);
wm_sprintf(InfoMsg, "OK\r\n" );
Info(InfoMsg);
ConnectFTP();
else
Info(InfoMsg);
Info(InfoMsg);
wm_sprintf(InfoMsg, "ERROR\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "CmdDOTAHandler2 :Exit\r\n" );
Info(InfoMsg);
s32 s32RetVal;
wm_sprintf(InfoMsg, "CmdFORMATHandler :Start With Event %d\r\n", params->Type );
Info(InfoMsg);
adl_adUnsubscribe(DOTA_Cell_Handle);
wm_sprintf(InfoMsg, "adl_adFormat Ret= %d\r\n", s32RetVal );
Info(InfoMsg);
if (s32RetVal == 0)
Info(InfoMsg);
else
Info(InfoMsg);
// OK */
//ADL_RET_ERR_UNKNOWN_HDL //if the handle is unknown */
//ADL_RET_ERR_NOT_SUBSCRIBED //if the service is not subscribed*/
//ADL_AD_RET_ERR_NOT_AVAILABLE //if A&D space is not available */
//ADL_RET_ERR_BAD_STATE //if there is at least one currently */
//subscribed cell or if a recompact/format process is running */
//ADL_RET_ERR_SERVICE_LOCKED //if called from a low level
wm_sprintf(InfoMsg, "CmdFORMATHandler :Exit\r\n" );
Info(InfoMsg);
s32 s32RetVal;
wm_sprintf(InfoMsg, "CmdINSTALLHandler :Start With Event %d\r\n" , params->Type);
Info(InfoMsg);
//Install The New Application
s32RetVal = adl_adInstall(DOTA_Cell_Handle);
if (s32RetVal != OK)
Info(InfoMsg);
else
Info(InfoMsg);
wm_sprintf(InfoMsg, "CmdINSTALLHandler :Exit\r\n" );
Info(InfoMsg);
s32 s32RetVal;
wm_sprintf(InfoMsg, "CmdCOMPACTHandler :Start With Event %d\r\n", params->Type );
Info(InfoMsg);
s32RetVal = adl_adRecompact(ADEventHandle);
wm_sprintf(InfoMsg, "adl_adRecompact Ret= %d\r\n", s32RetVal );
Info(InfoMsg);
if (s32RetVal == 0)
Info(InfoMsg);
else
Info(InfoMsg);
wm_sprintf(InfoMsg, "CmdCOMPACTHandler :Exit\r\n" );
Info(InfoMsg);
wm_sprintf(InfoMsg, "initvariables :Start\r\n" );
Info(InfoMsg);
ftp_DestAddr.Port = 21;
ftp_DestAddr.Mode = 1;
ftp_DestAddr.Type = 'A';
wm_sprintf(ftp_DestAddr.Server, "abc.aac.ds.aad");
wm_sprintf(ftp_DestAddr.Login, "waveccom");
wm_sprintf(ftp_DestAddr.Password, "MyPass");
wm_sprintf(ftp_DestAddr.FileName1, "hello.dwl");
wm_sprintf(ftp_DestAddr.FileName2, "file2.dwl");
wm_sprintf(APN_Details.APN_Name, "m3-world");
wm_sprintf(APN_Details.Username, "mms");
wm_sprintf(APN_Details.Password, "mms");
wm_sprintf(InfoMsg, "initvariables :Exit\r\n" );
Info(InfoMsg);
and here are Remote Shell Target :
adl_main tart InitType: -858993460
wip_netInit Ret= 0
initvariables tart
initvariables :Exit
adl_simSubscribe Ret= 0
adl_adEventSubscribe Ret= 0
App Version : 2
EXIT MAIN.
Sim_Handler tart with Event: 5
Sim_Handler :Exit
+WIND: 16
Sim_Handler tart with Event: 3
Sim Init Complete
GPRS_Attach tart
Connecting To GPRS…
wip_bearerOpen Retval: 0
wip_bearerSetOpts Retval: 0
wip_bearerStart Retval: -27
GPRS_Attach :Exit
Sim_Handler :Exit
+WIND: 4
+WIND: 10,“SM”,0,“FD”,0,“ON”,0,“EN”,0
+WIND: 11,“867EED28439F42574F680B55B7B933B2”,
gprs_bearer_handler tart with Event: 2
GPRS: CONNECTED IP=10.1.115.123 DNS1=10.1.10.11 DNS2=10.1.10.11
60751368
CmdDOTAHandler1 tart With Event 2048
hello.dwl -> OK
ConnectFTP tart
ConnectFTP tart-> !ftp_State
FTP Has Started Ok
FTP STARTED OK
ConnectFTP :Exit
ftp_SessionHandler tart with Event 2
WIP_CEV_OPEN
DOWNLOADING NEW APP
ftp_DataHandler tart with Event 2
WIP_CEV_OPEN
ftp_DataHandler tart with Event 6
WIP_CEV_WRITE
ftp_SessionHandler tart with Event 1
WIP_CEV_ERROR
ftp_DataHandler tart with Event 1
WIP_CEV_ERROR
ErrorNumber: 550
I try too pass this Error but i can’t find any way. Please help me!
