if who have a working code, show me please
The sample code provided by wavecom is actually sufficient but there is working code in this forum aswell but I think its comments are in spanish
Hi Her is some that I wrote last year to explain DOTA
I hope it still works (have not used it this year)
Dota By Walter Senekal 26 October 2005
Explained Ftp upload and FTP Download
#include "adl_global.h"
#include "ed_common.h"
#include "ed_dialup.h"
#include "ed_ftp.h"
#include "ed_gprs.h"
#include "ed_socket.h"
#include "ed_msgcodes.h"
/* Mandatory variables */
/* wm_apmCustomStack */
/* wm_apmCustomStackSize */
u32 wm_apmCustomStack [ 4000 ];
const u16 wm_apmCustomStackSize = sizeof ( wm_apmCustomStack );
/* Local variables */
ed_FTPSetupParams_t FTPParams;
ed_gprsSetupParams_t APNParams;
ed_FTPPutFileParams_t FTPPutFileParams;
ed_FTPPutFileParams_t FTPGetFileParams;
s32 Cell_Handle;
s32 S32Return;
/* Local functions */
void dotted_notation(unsigned long int hex_ip)
ascii array[30];
TRACE( ( 1, "Inside dotted_Notation" ) );
if (hex_ip==0x00000000)
return;
else
dotted_notation(hex_ip>>8 );
sprintf(array,"%d.",hex_ip & 0xFF);
adl_atSendResponse(ADL_AT_RSP,array);
u16 FTPGetDataHandler(u16 DataLen, u8 *pBData, TeDHandle id)
TRACE( ( 1, "Inside FTPgetDataHandler" ) );
TRACE((1,"Datalen=%d",DataLen));
if ( DataLen && pBData )
if (adl_adWrite(Cell_Handle,DataLen,(void*)pBData)!=OK)
TRACE((1,"Cannot Write To Cell"));
else
TRACE((1,"Successfully Written To Cell"));
// Always acknowledge all data
return DataLen;
void FTPGetRspHandler(s32 ResponseCode, TeDHandle id)
TRACE( ( 1, "Inside FTPgetRspHandler" ) );
TRACE((1,"handler response code: %d",ResponseCode));
switch(ResponseCode)
case ED_OK_FILE_TRANSFERED:
TRACE(( 1,"ED_OK_FILE_TRANSFERED"));
adl_adFinalise(Cell_Handle);
adl_atSendResponse(ADL_AT_UNS,"Installing New App");
S32Return=adl_adInstall(Cell_Handle);
TRACE((1,"Install return code: %d",S32Return));
break;
case ED_INFO_DATA_BEGIN:
TRACE(( 1,"ED_INFO_DATA_BEGIN"));
break;
case ED_ERR_DISTANT_DNS:
TRACE(( 1,"ED_ERR_DISTANT_DNS"));
break;
case ED_ERR_STACK_INTERNAL:
TRACE( ( 1,"ED_ERR_STACK_INTERNAL"));
break;
case ED_ERR_DISTANT_NO_RESP:
TRACE( ( 1,"ED_ERR_DISTANT_NO_RESP"));
break;
case ED_ERR_DISTANT_OPEN:
TRACE( ( 1,"ED_ERR_DISTANT_OPEN"));
break;
case ED_ERR_DISTANT_CD:
TRACE( ( 1,"ED_ERR_DISTANT_CD"));
break;
case ED_ERR_DISTANT_CLOSE:
TRACE( ( 1,"ED_ERR_DISTANT_CLOSE"));
break;
case ED_ERR_DISTANT_TCP_CLOSED:
TRACE( ( 1,"ED_ERR_DISTANT_TCP_CLOSED"));
break;
case ED_ERR_DISTANT_TCP_CLOSED_BY_PEER:
TRACE( ( 1,"ED_ERR_DISTANT_TCP_CLOSED_BY_PEER"));
break;
case ED_ERR_DISTANT_USERNAME:
TRACE( ( 1,"ED_ERR_DISTANT_USERNAME"));
break;
case ED_ERR_DISTANT_PASSWORD:
TRACE( ( 1,"ED_ERR_DISTANT_PASSWORD"));
break;
case ED_ERR_NETWORK_KO:
TRACE( ( 1,"ED_ERR_NETWORK_KO"));
break;
case ED_ERR_DISTANT_DATA_RETR:
TRACE( ( 1,"ED_ERR_DISTANT_DATA_RETR"));
break;
case ED_ERR_GPRS_SESSION_LOST:
TRACE( ( 1,"ED_ERR_GPRS_SESSION_LOST"));
break;
void WaitFtpFileSend(u8 ID)
s8 RetS8;
ascii Temp[255];
ascii *Mydata;
TRACE( ( 1, "Inside WaitFTPFileSend" ) );
wm_sprintf(Mydata,"WALTER_WALTER_WALTER_WALTER_WALTER_WALTER_WALTER");
RetS8 =ed_SendDataExt(Mydata, wm_strlen(Mydata), FALSE, ED_ID_FTP_PUT);
wm_sprintf(Temp,"Ret Code for edSendDataExt: %d",RetS8);
TRACE((1,Temp));
void TCPPutSendDataTimer(u8 ID)
s8 RetS8;
ascii Temp[255];
ascii Mydata[50];
TRACE( ( 1, "TCPPutSendDataTimer" ) );
RetS8 =ed_SendDataExt(Mydata, wm_strlen(Mydata), TRUE, ED_ID_FTP_PUT);
TRACE((1,Temp));
void FTPPutRspHandler(s32 ResponseCode, TeDHandle id)
s8 RetS8;
ascii Temp[255];
TRACE( ( 1, "Inside FTPPutRspHandler" ) );
ed_FTPGetFileGetConfig(&FTPGetFileParams);
TRACE((1,"filename"));
wm_strcpy(FTPGetFileParams.FtpPutFilename,"Hello.dwl");
TRACE((1,"path"));
wm_strcpy(FTPGetFileParams.FtpPutPath,".");
TRACE((1,"FTPGetFileSetConfig"));
RetS8=ed_FTPGetFileSetConfig(&FTPGetFileParams);
wm_sprintf(Temp,"%d",RetS8);
TRACE((1,Temp));
adl_atSendResponse(ADL_AT_UNS,"\r\nGet File\r\n");
ed_FTPGet(FTPGetRspHandler,FTPGetDataHandler);
break;
case ED_INFO_WAITING_FOR_DATA:
adl_tmrSubscribe(FALSE,50,ADL_TMR_TYPE_100MS,TCPPutSendDataTimer);
break;
break;
break;
break;
break;
break;
case ED_ERR_DISTANT_SEND:
TRACE( ( 1,"ED_ERR_DISTANT_SEND"));
break;
break;
break;
break;
break;
break;
break;
break;
void FTPPutDataHandler(u16 MaxLen, TeDHandle id)
TRACE( ( 1, "Inside FTPDataHandler" ) );
TRACE((1,"maxsize=%d",MaxLen));
void dialupHandler( s32 responseCode)
s8 RetS8;
ascii Temp[255];
ed_dialupIPInfos_t ip_info;
TRACE( ( 1, "Inside dialupHandler" ) );
switch ( responseCode )
case ED_OK_GPRS_SESSION_SET://GPRS session is set.
TRACE( ( 1, "Inside ED_OK_GPRS_SESSION_SET" ) );
ed_DialupGetIpInformations(&ip_info); //retrieve ip informations (retrieved as u32).
adl_atSendResponse(ADL_AT_RSP,"\r\nLocal ip is ");
dotted_notation(ip_info.LocalIP);//Print the ip information in dotted format
adl_atSendResponse(ADL_AT_UNS,"\r\nSending File\r\n");
ed_FTPGetConfig(&FTPParams);
TRACE((1,"pw"));
wm_strcpy(FTPParams.FtpPw,"<enter ftp password>");
TRACE((1,"un"));
wm_strcpy(FTPParams.FtpUn,"<eneter ftp username>");
TRACE((1,"serv"));
wm_strcpy(FTPParams.FtpServ,"<enter your server address>");
TRACE((1,"SetConfig"));
RetS8=ed_FTPSetConfig(&FTPParams);
TRACE((1,Temp));
ed_FTPPutFileGetConfig(&FTPPutFileParams);
wm_strcpy(FTPPutFileParams.FtpPutFilename,"walter.txt");
TRACE((1,"path"));
wm_strcpy(FTPPutFileParams.FtpPutPath,".");
TRACE((1,"FTPFileSetConfig"));
RetS8=ed_FTPPutFileSetConfig(&FTPPutFileParams);
TRACE((1,Temp));
ed_FTPPut(FTPPutRspHandler,FTPPutDataHandler);
break;
case ED_INFO_CONNECT:
TRACE( ( 1, "Inside ED_INFO_CONNECT" ) );
break;
case ED_OK_PPP:
TRACE( ( 1, "Inside ED_OK_PPP" ) );
adl_atSendResponse(ADL_AT_UNS,"\r\nLocal ip is ");
break;
case ED_OK_ON_HOOK:
TRACE( ( 1, "Dial up connection closed" ) );
adl_atSendResponse( ADL_AT_UNS, "\r\nDial up connection closed" );
break;
case ED_ERR_GPRS_ABORTED:
TRACE((1,"ED_ERR_GPRS_ABORTED"));
adl_atSendResponse(ADL_AT_UNS,"\r\nInternal GPRS error.Please check your APN parameters");
break;
default:
TRACE((1,"default or error received in gprsHandler: responseCode - %d", responseCode));
adl_atSendResponse( ADL_AT_UNS, "\r\nerror received in dial up connection start" );
break;
void timerHandler(u8 ID)
s8 returnCode;
TRACE( ( 1, "Inside timerHandler" ) );
returnCode = ed_DialupConnectionStart(dialupHandler );
if(returnCode == 0)
TRACE((1,"ed_DialupConnectionStart success returnCode = %d",returnCode));
adl_atSendResponse(ADL_AT_UNS,"\r\nTrying to retrieve ip information.Please wait until local ip is received...\r\n");
else
adl_atSendResponse( ADL_AT_UNS, "ed_DialupConnectionStart failed" );
TRACE((1,"ed_DialupConnectionStart failed returnCode = %d",returnCode));
void GPRSWait( u8 ID)
s8 returnCode;
TRACE( ( 1, "Inside GPRSWait" ) );
wm_strcpy( APNParams.ApnUn,"");
wm_strcpy( APNParams.ApnPw,"");
wm_strcpy( APNParams.ApnServ,"internet");
APNParams.Cid=1;
APNParams.Mode=1;
returnCode = ed_GprsSetConfig( &APNParams );
if (returnCode == 0)
adl_tmrSubscribe(FALSE, 10, ADL_TMR_TYPE_100MS,timerHandler);
else
TRACE((1,"ed_GprsSetConfig failed returnCode = %d",returnCode));
bool AttRspHandler(adl_atResponse_t *params)
TRACE( ( 1, "Inside AttRspHandler" ) );
//if an OK is received as response to AT+CGATT=1 command then set GPRS settings.
if( !wm_strncmp( params->StrData, "\r\nOK", 4 ) )
//Ready
adl_tmrSubscribe(FALSE,2,ADL_TMR_TYPE_TICK,GPRSWait);//Give modem time to process CGATT=1
//if an OK is not received then create AT+CGATT=1 again.
else
adl_atCmdCreate( "AT+CGATT=1", FALSE, AttRspHandler, "*", NULL );
return TRUE;
void SetupHandler(u8 ID)
TRACE( ( 1, "Inside SetupHandler" ) );
adl_atCmdCreate("AT+CGATT=1",FALSE,AttRspHandler,"*",NULL);
void simeventHandler(u8 Event)
switch(Event)
case ADL_SIM_EVENT_REMOVED:
break;
case ADL_SIM_EVENT_INSERTED:
break;
case ADL_SIM_EVENT_FULL_INIT:
break;
case ADL_SIM_EVENT_PIN_ERROR:
break;
case ADL_SIM_EVENT_PIN_OK:
break;
case ADL_SIM_EVENT_PIN_WAIT:
break;
case ADL_SIM_EVENT_PIN_NO_ATTEMPT:
break;
ascii MyCmd[10];
TRACE (( 1, "Inside adl_main" ));
ed_Init();
adl_atSendResponse(ADL_AT_UNS,"App Starting Please Wait 10 Seconds");
adl_simSubscribe(simeventHandler,NULL);
adl_tmrSubscribe(FALSE,100,ADL_TMR_TYPE_100MS,SetupHandler);
adl_atCmdCreate("AT+CGCLASS=\"B\"",TRUE,NULL,NULL);
Cell_Handle= adl_adSubscribe(1,ADL_AD_SIZE_UNDEF);
if (Cell_Handle>=0)
TRACE(( 1,"Cell succesfully subscribed"));
else
TRACE((1,"Can do write to cell"));
if (InitType = ADL_INIT_DOWNLOAD_SUCCESS)
adl_adDelete(Cell_Handle);
App Will First Upload A File To FTP Server and
then Download the Hallo_World.wpb.dwl from the FTP server.
On Completion It will Install It
Reset
and Run The New App
To Do In App To Be downloaded: Delete App on startup
How?
Ans:Init Type will return "ADL_INIT_DOWNLOAD_SUCCESS" in main
(As shown In Main)(Not tested yet,but works in principle)
Hi Everybody
i have created a new DOTA application using the WIP stack
You can fild it at http://www.wavecom.com/modules/movie/scenes/forums/viewtopic.php?t=1330
