Does MC7411 support SIM hot swap?
I checked the MC7411 specs and found that the pin is not detected by SIM.
The AT command guide found the AT!CUSTOM=“SIMHOTSWAPDIS” command.
So, does MC7411 support SIM hot swap function?
It is working on my EM7565 (same chipset as MC7411).
at!custom?
!CUSTOM:
             GPSENABLE          0x01
             GPSLPM             0x01
             IPV6ENABLE         0x01
             UIM2ENABLE         0x01
             SIMLPM             0x01
             USBSERIALENABLE    0x01
             SINGLEAPNSWITCH    0x01
             QXDMLOGENABLE      0x01
at+cpin?
+CPIN: READY
at!uims?
!UIMS: 0
//here remove the SIM card
at+cpin?
+CME ERROR: SIM not inserted
//here insert again the SIM card
at+cpin?
+CPIN: READY
ati3
Model: EM7565
Revision: SWI9X50C_01.14.22.00 ba8ef1 jenkins 2022/11/11 09:59:48
IMEI: 353533103912345
IMEI SV: 15
FSN: UF221731112345
+GCAP: +CGSM
Hi @jyijyi
I just tested it with MC7411, and I can’t use SIM card hot swapping.
And I found that there is no pin for SIM detection in the MC7411 specification.
ati
ati
Model: MC7411
Revision: SWI9X50C_01.13.02.00 22fdf9 jenkins 2020/06/16 16:29:59
IMEI: 352418420101527
IMEI SV: 11
FSN: 8Y0304008304AB
+GCAP: +CGSM
at!custom?
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
at+cpin?
at+cpin?
at+cpin?
at+cpin?
at+cpin?
at+cpin?
at+cfun=0
at+cfun=0
at+cfun=1
at+cfun=1
at+cpin?
at+cpin?
so it cannot read all sim card in your environment?
Yes, the card cannot be detected.
I have tested different modules and different SIM cards, but they cannot use hot swap.
so after power up, it is OK to detect SIM card, right?
have you checked AT!UIMS?
Have you also tested in EM7411 modules with development kit?
I have confirmed that the SIM slot is consistent with the UIMS setting…
Yes, the SIM can be recognized after power up.
MC7411 not tested on development kit.
EM7411 can support SIM hot swap after testing.
So I think it’s a hardware problem caused by no SIM detect pin.
I don’t see such SIM detect feature in the MC7411 specification.
