Developer Studio in Eclipse - Ubuntu Linux
I’m trying to install the developer studio in eclipse on ubuntu 12.04. I have followed the instructions in the release notes, but get the following error every time I try to install something (ie the developer studio full or even just the individual pieces - toolkits, base package, etc):
An error occurred while installing the items
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]com.wavecom.openat.ide.ebs.armeabigcc.linux 4.4.1, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.ChmodAction).
The action chmod failed - file /usr/lib/eclipse/tools/armeabigcc/4.4.1 does not exist.
This error seems to indicate that I don’t have the EABI toolchain installed, but it shows up even if I just try to install the EABI toolchain.
What am I doing wrong here? Has anyone else run into this?
We already got some feedback about this kind of behavior.
Did you install Eclipse through the Ubuntu package? If so, you may indeed have some troubles when trying to install the toolchains, since the install process requires some chmod operation on location your user may not have enough privileges.
Recommended procedure is to download & extract the Eclipse archive from eclipse.org/downloads/packag … e/juno/sr1, in order to let your user completely “own” the Eclipse install.
We’re looking forward to provide a better integration with Ubuntu package management system in future versions.
cool - thanks for the tip. That got my further in as much as I was able to install the developer studio stuff without error. When I re-opened eclipse and tried to create an OpenAT project however (new project->Open AT App) I got blank templates in the wizard (no controls, no options) and I wasn’t able to click next or finish to actually create the project. In windows this is where there are a bunch of options as to which firmware and which target you are building on. This was after installing the three available toolchains and using the ‘all-in-one’ Developer Studio 2.3 version. When I went to try to use the Target Management perspective (ie Perspectives->Other, Target Management) nothing happens - no error, no window, no nothing. I figured I was missing some dependency or library or something so I just started installing every package available from Sierra. Now when I go to start my eclipse I get a stupid error about my workspace being invalid or readonly and much different error in the logs:
I switched to linux because windows was giving me unreliable behavior in terms of talking to the module (sporadic disconnects and freezes - I’ve got another post on that), but linux is turning out to be a huge pain as well. Sorry for including the entire log file (I tried to trim down obvious duplicates), but you can see the error on startup which is a library not found error about unix-java as well as the new project error which was silent to me as the user (some sort of null point error caught and swallowed by the GUI).
Strange game. The only way to win is not to play.
!SESSION 2012-12-19 09:19:47.030 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.6.0_24
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY com.swi.tm.core 4 0 2012-12-19 09:19:50.562
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in com.swi.tm.core.Activator.stop() of bundle com.swi.tm.core.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:791)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:510)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:692)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.UnsatisfiedLinkError: no unix-java in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1681)
at java.lang.Runtime.loadLibrary0(Runtime.java:840)
at java.lang.System.loadLibrary(System.java:1047)
at cx.ath.matthew.unix.UnixSocket.(UnixSocket.java:40)
at org.freedesktop.dbus.Transport.connect(Transport.java:772)
at org.freedesktop.dbus.Transport.(Transport.java:737)
at org.freedesktop.dbus.DBusConnection.(DBusConnection.java:299)
at org.freedesktop.dbus.DBusConnection.getConnection(DBusConnection.java:282)
at com.swi.tm.core.utils.dbus.daemon.DBusDaemon.start(DBusDaemon.java:128)
at com.swi.tm.core.utils.dbus.daemon.DBusDaemon.(DBusDaemon.java:48)
at com.swi.tm.core.utils.dbus.DBusDeviceManager.(DBusDeviceManager.java:48)
at com.swi.tm.core.utils.dbus.DeviceManagerService.getInstance(DeviceManagerService.java:21)
at com.swi.tm.core.utils.USBEventManager.(USBEventManager.java:49)
at com.swi.tm.core.Activator.stop(Activator.java:45)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:771)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:764)
… 19 more
Root exception:
!SESSION 2012-12-19 09:32:19.697 -----------------------------------------------
!ENTRY com.wavecom.spm.udc 2 0 2012-12-19 09:43:37.131
!MESSAGE /home/jwl38/eclipse/configuration/user.properties (No such file or directory)
!STACK 0
java.io.FileNotFoundException: /home/jwl38/eclipse/configuration/user.properties (No such file or directory)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.(FileInputStream.java:137)
at java.io.FileInputStream.(FileInputStream.java:96)
at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:87)
at sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:178)
at java.net.URL.openStream(URL.java:1031)
at com.wavecom.spm.spmudc.impl.UserInfoImpl.loadFromProperties(UserInfoImpl.java:311)
at com.wavecom.spm.spmudc.impl.InstallInfoImpl.init(InstallInfoImpl.java:332)
at com.wavecom.spm.update.PostInstallCheck.performCheck(PostInstallCheck.java:17)
at com.wavecom.spm.inet.ExtensionsManager.handleSteps(ExtensionsManager.java:130)
at com.wavecom.spm.inet.INetChecksJob.run(INetChecksJob.java:72)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
!SESSION 2012-12-19 09:46:27.857 -----------------------------------------------
Framework arguments: -product org.eclipse.epp.package.cpp.product
Command-line arguments: -os linux -ws gtk -arch x86_64 -product org.eclipse.epp.package.cpp.product
!ENTRY org.eclipse.ui 4 0 2012-12-19 09:47:30.003
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.RuntimeException: org.eclipse.core.runtime.CoreException: Plug-in com.swi.tm.ui was unable to load class com.swi.tm.ui.TMPerspective.
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:500)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:481)
at org.eclipse.ui.actions.PerspectiveMenu.runOther(PerspectiveMenu.java:376)
at org.eclipse.ui.actions.PerspectiveMenu$3.runWithEvent(PerspectiveMenu.java:130)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
Caused by: java.lang.RuntimeException: org.eclipse.core.runtime.CoreException: Plug-in com.swi.tm.ui was unable to load class com.swi.tm.ui.TMPerspective.
at org.eclipse.ui.internal.registry.PerspectiveDescriptor.createFactory(PerspectiveDescriptor.java:78)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3602)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.openPerspective(ShowPerspectiveHandler.java:146)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.openOther(ShowPerspectiveHandler.java:118)
at org.eclipse.ui.handlers.ShowPerspectiveHandler.execute(ShowPerspectiveHandler.java:57)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
… 37 more
Caused by: org.eclipse.core.runtime.CoreException: Plug-in com.swi.tm.ui was unable to load class com.swi.tm.ui.TMPerspective.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.registry.PerspectiveDescriptor.createFactory(PerspectiveDescriptor.java:74)
… 48 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.swi.tm.ui (484).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
… 52 more
Caused by: org.osgi.framework.BundleException: The activator com.swi.tm.ui.Activator for bundle com.swi.tm.ui is invalid
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:172)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:679)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
… 64 more
Caused by: java.lang.NoClassDefFoundError: com/swi/tm/model/services/ServiceHandler$MultipleServiceListener
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2406)
at java.lang.Class.getConstructor0(Class.java:2716)
at java.lang.Class.newInstance0(Class.java:343)
at java.lang.Class.newInstance(Class.java:325)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadBundleActivator(AbstractBundle.java:167)
… 70 more
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.swi.tm.model (473).
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:35)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at com.wavecom.openat.ide.ebs.targetbinding.ui.hw.AutoDetectionTable.createCheckboxTableViewer(AutoDetectionTable.java:174)
at com.wavecom.openat.ide.ebs.targetbinding.ui.hw.AutoDetectionTable.(AutoDetectionTable.java:59)
at com.wavecom.openat.ide.ebs.targetbinding.ui.AutoDetectionForNewProject.createCompositeAutoDetect(AutoDetectionForNewProject.java:54)
at com.wavecom.openat.ide.ebs.targetbinding.ui.AutoDetectionForNewProject.createTab(AutoDetectionForNewProject.java:37)
at com.wavecom.openat.ide.ebs.ui.wizards.newproject.pages.hw.AbstractPageHW.createModuleComposite(AbstractPageHW.java:84)
at com.wavecom.openat.ide.ebs.ui.wizards.newproject.pages.hw.AbstractPageHW.createWidgets(AbstractPageHW.java:60)
at com.wavecom.openat.ide.ebs.ui.wizards.newproject.pages.hw.OpenATPageHW.createWidgets(OpenATPageHW.java:42)
at com.wavecom.openat.ide.ebs.ui.wizards.newproject.pages.hw.AbstractPageHW.createContents(AbstractPageHW.java:51)
at com.wavecom.openat.ide.ebs.ui.wizards.newproject.pages.AbstractNewProjectWizardPage.createControl(AbstractNewProjectWizardPage.java:51)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.java:174)
at com.wavecom.openat.ide.ebs.ui.wizards.newproject.AbstractNewProjectWizard.createPageControls(AbstractNewProjectWizard.java:233)
at org.eclipse.jface.wizard.WizardDialog.createPageControls(WizardDialog.java:736)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog.java:1182)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDialog.java:1241)
at org.eclipse.jface.wizard.WizardDialog.access$4(WizardDialog.java:1238)
at org.eclipse.jface.wizard.WizardDialog$8.run(WizardDialog.java:1227)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog.java:1225)
at org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advanceToNextPageOrFinish(NewWizardSelectionPage.java:71)
at org.eclipse.ui.internal.dialogs.NewWizardNewPage$2.doubleClick(NewWizardNewPage.java:368)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1477)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction.java:117)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
… 29 more
Caused by: org.osgi.framework.BundleException: Exception in com.swi.tm.model.Activator.start() of bundle com.swi.tm.model.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
… 76 more
Caused by: java.lang.NullPointerException
at com.swi.tm.core.SerialPortComponent.setSendAtInDevMode(SerialPortComponent.java:133)
at com.swi.tm.model.Activator$1.refreshSetAtCommandMode(Activator.java:64)
at com.swi.tm.model.Activator$1.servicesAvailables(Activator.java:52)
at com.swi.tm.model.services.ServiceHandler$1.addingService(ServiceHandler.java:115)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:932)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:317)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:261)
at com.swi.tm.model.services.ServiceHandler.startListeningService(ServiceHandler.java:128)
at com.swi.tm.model.Activator.start(Activator.java:71)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
… 82 more
!ENTRY org.eclipse.ui 2 2 2012-12-19 09:48:15.141
!MESSAGE Invalid property category path: ValidationPropertiesPage (bundle: org.eclipse.wst.xml.ui, propertyPage: org.eclipse.wst.xml.ui.propertyPage.project.validation)
You’re close to the end.
Please refer to the release note: developer.sierrawireless.com/en/ … 2_3_0.aspx
Here are explained some requirements for Target Management handling under Linux (some packages to be installed…)
