Dev kit for EM8695
Can anyone confirm that the Air Prime dev kit (EM DEV KIT-6001173) works with the EM8695 please? and/or what have you tested with?
You can see this migration guide
It should be pin compatible (except some pins) with EM7411
Thanks. So 6001173 kit would be fine for testing basic functions (sending, receiving, measuring power consumption)?
Yes, I remember I can have correct USB enumeration with this dev kit and EM8695
Is there the original user guide for this dev kit? The only one I can find is two pages. For now, we will try installing the windows driver and then see if the EM/MC series connection manager and/or fdt sees the device?
the 2 page guide is the only user guide i have for 6001173
Does our approach sound right?
you can install the Windows driver and see if you can communicate with the AT command port first:
https://source.sierrawireless.com/resources/airprime/software/em86/em8695-windows-drivers/
BTW, EM8695 is using the MBIM interface, so you don’t need to use the EM/MC connection manager.
Default Windows application should be able to establish data connection via MBIM interface.
The EM8695 Product Technical Spec shows a requirement for 470 and 2200uF capacitors, but there is no indication of whether they are on the eval kit or not, and no schematic or layout to assist if I wanted to install them. Can we get schematics and layout? Can you at least confirm whether or not caps are on the 6001173 eval board? I’ve been able to connect to LTE. Does that imply that it’s working as is? Or will it work “better” if I add more capacitors?
If it can attach network and respond on AT command, then it should be fine now
Maybe I can help. I follow you.
I checked the latest module firmware version available. It is version, SWIX35C_02.01.03.00
I reviewed the release notes, too. So important fixes included.
You can find the FW here, Sierra Wireless™ EM8695 Approved FW Packages | Source
You can query the current module firmware version with an AT command, ati
Or you can query the version via the Windows Mobile Broadband Connection Manager.:grinning_face:
@james.hillman
@mike.kaelin
Officially speaking, we would recommend customer to use the latest dev kit for EM8695 instead of the old dev kit.
For EM DEV KIT-6001173, we saw that there might be some pin not fully compatible with EM8695.
For example, Pin 6 is pulled up to module VCC.
However, according to EM8695 PTS, max input for Pin 6 is 3.6V max, which is lower than the max value for VCC (4.4V).
Can you provide the part number / weblink to order the latest kit please?
the dev kit SKU is 6001542
You need to contact distributor to get this SKU
