I’m trying to make initial contact with an LX40 modem’s web configuration over the air as a test prior to doing more advanced configuration. https: and I can’t seem to contact it. It’s possible that it’s the connection, but I can see that the modem has acquired and ip number from the provider and I can see from the lights that it has at least an ok connection. I also seem to see the receive light blink randomly when I do this and make contact. However, there is no response from the modem. I think I’m doing things correctly, but clearly something is wrong. I see that I can send the config to you all. Could I get someone take a look at it if I upload it? There are a lot of settings and I’ve been working on this for weeks trying different them and different port numbers, but with no luck.
Based on your description, I understand that you want to access ACEmanager of the LX40 over cellular, is that correct?
In order to remote access, as far as I know, there are two possible ways:
Option 1: Your gateway has a public IP assigned by your mobile service provider.
Option 2: If the device is used on a private network, the private network needs to support routing.
Please recheck with your network provider to confirm this.
By default remote access to ACEmanager is disabled for security purposes.
Go to ACEManager:
I checked settings and also tried another cell operator and SIM card. I have no idea what the problem is. Two files should be attached to this email. If they are not, something has gone wrong with getting them into your system and I can resent some other way.
Brecky
(Attachment template_debugucscedu12192024.xml is missing)
