After upgrading to 4.15.3, the manual “Switch Active Sim” button no longer works reliably. It will always work first try after a reboot, but after subsequent tries, it may or may not swap the sim, more than likely it will not even though it says the command was sent ok.
To reproduce:
- Restart the modem
- Click “Swap Active Sim” - wait for the Active Sim to switch to the other card
- Click the “Swap Active Sim” button again.
- Repeatedly try swapping Sim cards - eventually it may work once again but it never reliably.
- Restart the modem again
- Swap the sim again, it will work because the modem has just rebooted.
- Try swapping the sim card again, it will only randomly work again now.
It would be really helpful to have this feature working again, the current workaround is to change primary and secondary sim profiles then reboot the device.
Thank you.
Hi @alex.meyer
I tested your case on my RV50X with ALEOS Version 4.15.3 and I didn’t observe the your issue. Could you please try my steps as following:
- Restart the modem, Active Sim is Slot 1
- “Target SIM Slot” is Slot 2 ==> Click “Switch Active Sim” ==> Click “Refresh” few times and wait for the Active Sim to switch Slot 2
→ Now, the Active Sim is Sim slot 2
<If you want to change Active SIM to Slot 1>
- Change “Target SIM Slot” to Slot 1 ==> Click “Apply” ==> Click “Switch Active Sim” ==> Click “Refresh” few times wait for the Active Sim to switch Slot 1
→ Now, the Active Sim is Sim slot 1
Hi Jerdung, thanks for the reply. That’s exactly what I’ve been doing.
Here’s a video of what I’m experiencing:
I recommend downloading it for the best quality.
You can see it only seems to work sometimes…
Hi @alex.meyer
I can’t watch your video, is there any other way I can watch it?
Hello Jerdung,
I tested with Firmware 4.18.1 and the result is the same. Switch Active SIM doesn’t work and the modem reboot.
| ALEOS Software Version: |
4.18.1 |
ALEOS Build number: |
002 |
| Device Model: |
RV50X |
| Radio Module Type: |
MC7455 |
Radio Module Identifier: |
GENERIC |
| Radio Firmware Version: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30 |
I can share to you logs in private if required. Thanks for your support.
Please Ignore my last comment, I found our problem, it was a webpage configured to interact with the modem that was always revert my change to sim 1 and reboot the modem.
When I disable the service that runs the program, the modem response as it should be :
Switch Active SIM change Active sim 1 to sim 2 successfully
Have a nice day.
Max
