hello,everyone.
When I use the Auto Detect function of the Target Mornitor Tool,it always return “no match”.But through the UartAssist,I send the AT command, i get the right return value.
The situation is same in another computer.
Anyone comfronted the same problem ?
Many thanks for your help!
could you check if autobauding is used (+IPR: 0)? Indeed, “Auto detect” does not work if autobauding is used. In this case, you have to specify a value different from “Autobauding” (e.g. AT+IPR=115200).
Regards,
Kevin
