Hi ,
device : Fastrack Supreme , firmare ver.:
R73_00gg.FSU001 2087432 121208 15:34
at+wopen=2
+WOPEN: 2,“AT v06.20”
when i try to execute this command i get an error.
i do following :
AT+WOPEN=1
AT+WIPCFG=?
ERROR
this seems to me that device cannot start IP stack.
please help with the solution
awneil
March 27, 2009, 12:56pm
2
That shows that there is no application loaded.
With an application loaded, you would get two version numbers in the response
True - it can’t start the stack if you haven’t loaded it into the module!
awneil:
So what should i do to get working IP stack , without application loading. i’m just using AT+WIP commands to test functionality. ?
awneil
March 27, 2009, 1:46pm
5
You clearly need to speak to your supplier!
