Hi all,
my company has a lot of q2686RD.
I’ve connected it to my pc serial port and was able to receive “ok” after sending AT.
but any other AT command only returns error.
the unit is placed on the dev kit 3.2.
boot is off and uart 1 is enabled.
the modem is from the factory. meaning its FW is the original one with no modification at all.
thanks , dor.
the at+cmee=1 got me error.
i noticed after leaving the modem for a while it is sending +wdwl
so i tried AT+CFUN=1
the modem went in to reset.
but it didnt fixed anything.
Dor.
So this is all pretty old now and having to do this from memory but if you are seeing +wdwl coming out then it implies the unit is in a download mode and given the lack of response to the other commands it may well not be in a good place operationally.
Hi matt, if i may few more question.
1-every action i take regarding the sim is returned with +CME ERROR: 3
the open at doc state: “Operation not allowed
Access techno param filled while the
SIM/UICC file does not support it”
do you know/ remember how to remedy this?
2-when i used the xmodem you asked me to download the dwl.dwl file before the FW its self, what is the purpose of this file?
thanks.
dor.
Fairly sure the unit is in operable/not running the proper firmware at the moment because it should respond to some of the commands such as ati and at+cgmr regardless of the state of the SIM or the network.
Re the dwl.dwl file, it is the bootloader that the unit will use to download the main firmware with, it never changed much but was always good practice to download first especially in your case where we have no idea what is currently in it.
