I have several tries passed by until I wrote that message into this forum. I dont get any AT commands working after I tried to get some traces out of the Q2686H. After a download and an erase (all three checkboxes) the modem does not respond anymore. The DWLWin application works fine. In the Target Monitoring Tool I clicked on “Safe Target”, which does not bring up any change.
Thx
Schneeweiss
I also tried to update the firmware…
still the DWLWin tool is the only prog which communicates to the Board!
What I did in detail after I recognized that the AT command do not work anymore:
First
- delete Objects, Customization Files and Open AT Application
- download of the Application
Second
- download of the firmware R71a01-cus-q26-01.wpk (after that I got a bad software message on the serial link)
- download of the Open AT application (bad software message disappears)
But I have no luck, so the AT commands still dont work!
PS: The Q2686H is settled on a Q26 Developer Board
Since downloading the firmware gives you a bad software message, i don’t think downloading an Open AT application after that would help to resolve the issue.
Since you are using a .wpk package to re-download the firmware, the possibility of the firmware getting corrupted can also be eliminated. I would suggest you to get in touch with your Wavecom contact (may be the distributor?).
Thank you guys.
I had a very old Revision of the wireless cpus which were corrupted due to firmware updates. Now I have got new cpus and they are working fine.
schneeweiss
