As to memorize data in memory
I have a Wavecom Fastrack M1306B.
In my application I want to memorize some data (type text files) that they later will be sent with a TCP socket.
I am a confused, In the guide I have found different memory functions:
adl_memory.h , adl_flash.h , adl_ad.h .
What can I use for my application?
Can I find samples that they can help me ?
Thank
adl_memory is RAM; ie, it is volatile.
adl_flash and adl_ad are both non-volatile.
So, the first question is: do you require volatile or non-volatile storage?
As to whether to choose Flash or A&D for non-volatile storage, the Wavecom documentation is typically unhelpful on this matter!
I require non-volatile storage.
I want only to store data recieved through the UART1 and after to read
Have you some example in order to write and to read whit adl_flash or adl_ad ?
Hello and thanks
The Wavecom Application Download sample illustrates the use of A&D Storage;
Several of the Wavecom samples use Flash for non-volatile parameter storage; eg, the Telemetry and Ping samples
