Hi to all!, im really confused about the reight use of the A&D memory. For wich i understand, i can use this memory to save data and a dwl file. The Oat Memory is only used for the aplicattion?, can i store data in that memory?. Im asking this because if i resize the A&D i loose all the data stored in there, and that would be catastroffic to me!.
Im developing a product who need a lot of Flash memory. So writing in he A&D looks great, but i need to use the DOTA too…
I think i might. But, i can use use the A&D to save dwl files and ordinary data?. I read somewhere that the granularity is 64Kbytes, is this true?, if i need to erase a cell i will erase 64Kbytes of data???.
You may ask Wavecom to confirm 64BK minimum erase block or you can read datasheet of flash used in Wavecom modules. Generally you can treat A&D as a simple file system: a cell as a file with random read (adl_adInfo) and senquential writing only. You do not worry about how to erase (delete in A&D) cell detail, you just call adl_adDelete in your app when the cell is not needed, similar to delete a file in other OS. However, deleting cell does not mean the cell space is released. You have to call adl_adRecompact to release the cell space. I guess adl_adRecompact does erasing processing. All A&D operations will be failed within low level interrupt.
If accessing flash in your app is critical, I suggest you use external flash, such as AT45XX, ranging from 4MB to 16MB with serial (compatiable SPI) interface and byte read/write capability. Therefore, AT45XX can be used as a circular buffer with a great flexibility. However, A&D is not. Frankly A&D implementation might be based on improper design or the designer could have knowledge limitation when proposal of A&D specifications.
Thanks yuantuh!!!, i know that is not as flexible as an external memory but its worth to giving a try!. I think a posible solution is to use the RAM to work with the 64Kbytes and do all the ops there and then write to the A&D memory.
Ill use your guidence to my libraries. I have a another problem with this theme. I posted a minute ago in the same category a new message, in order to not make a mess here i wont paste the link.
