I have received Realview Developer Suite(Evaluation CD), and started to work on it. When I compile file ‘Hello_World’ in Win32 Debug mode(Hello_World_rte), everything is OK, and I can run embedded application on WISMO evaluation board. But, here is a problem: When I compile file ‘Hello_World’ in Win32 Wismo_Target (Hello_World), I get the following message:
SGT_VER = v1.2.11
SGT_DIR = /cygdrive/C/OpenAT/Tools/SGT/v1.2.11
Scripts path for SGT :
/cygdrive/C/OpenAT/Tools/SGT/v1.2.11/script_sgt
Type help_sgt for a list of SGT commands
Check environment settings…
Launch a full library or binary process
---------------------------------------… Dependency graph is being built …
../out/arm_Hello_World_32.dep
… Build sources filtering rules for arm_Hello_World_32
../out/arm_Hello_World_32.flt
Get …/…/src/hello_world.c hello_world.c
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_types.h wm_types.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_apm.h wm_apm.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_stdio.h wm_stdio.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_remote.h wm_remote.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_at.h wm_at.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_bases.h wm_bases.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_io.h wm_io.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_os.h wm_os.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_fcm.h wm_fcm.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_bus.h wm_bus.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_list.h wm_list.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_scmem.h wm_scmem.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_gprs.h wm_gprs.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_snd.h wm_snd.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_ad.h wm_ad.h
Get C:/OpenAT/V303/TgtGen/WmHeader/wm_gps.h wm_gps.h
… Compiling hello_world.c
C:\Program Files\ARM\RDI\Targets\Remote_A\1.3.1\113\eval2-sc\win_32-pentium;C:\Program Files\ARM\RDI\rdimsvr\1.3.1\113\eval2-sc\win_32-pentium;C:\Program Files\ARM\RVARMulator\v6ARMulator\1.4.1\241\eval2-sc\win_32-pentium;C:\Program Files\ARM\RVARMu
lator\ARMulator\1.4.1\211\eval2-sc\win_32-pentium/tcc: not found
make: *** [hello_world.o] Error 127
Find errors occurred when using SGT
Analyze errors in Log files
WARNING : arm_Hello_World_32_status.log is incomplete. Check manually if any errors exist
Analyze errors in tmp files if they exists.
Libraries available in out directory :
End process.
Hello_World - 1 error(s), 1 warning(s)
Compiler doesn’t make output file “arm_Hello_World_32.wpb.dwlâ€, and get Error 127. Can you help me to solve this problem with ARM compiler? Thank you in advance!
