AirPrime EM7455 Esim support?
Does my AirPrime EM7455 support Esim?
And how to fix this?.. i cannot find any network.
FDT version: 1.0.1702.1
Awaiting adapter …
Setting images preference …
Resetting …
Awaiting download port …
Enabling selective suspend …
Firmware download failed.
Primary error code: 82 - Failed in checking modem mode.
Secondary error code: 5 - Neither NDIS adapter nor serial port is available.
Device error code: 0x0 - Unknown device error code.
Current:
Firmware:
ImageId: 002.072_000
BuildId: 02.24.03.00_GENERIC
Configuration:
Final images information:
Current:
Firmware:
ImageId:
BuildId:
Configuration:
ImageId:
BuildId:
OEM PRI:
IMEI:
Total time elapsed: 38172 ms.
Time to switch to boot mode: -1 ms.
Images downloaded:
Press Enter to continue …
See here on how to get back the serial ports
I cannot see it as modem, it only shows as network adapter.
Tried using it with the configuration.ini but without succes.
I have tried installing the Genericdriver with the following configurations:
“USBCOMP=8”
“USBCOMP=9”
“USBCOMP=99”
Full configuration.ini:
[Default Values]
CHECKFORDEVICE=0
LOCATIONDRIVER=1
WIN8LOCATION=1
USBCOMP=8
no idea then, as other user can make it work
I have now installed the 4581.exe and i get the following… maybe you know now how to help?
maybe you install 5087 version again then, as module already enumerates AT command port
It did not work. Any other ideas? :frowning:
you can install virtual machine of ubuntu linux and see if it works
If it works , then it is your windows problem
