AirPrime EM7345 GPS AT commands
I have an AirPrime EM7345 card installed in a Lenovo X1 Carbon (Gen2) laptop.
The card works ok as a WAN network card.
I need to use AT GPS commands to get location data from the card.
I can send AT commands to card (like ATZ or AT+XGENDATA) and I receive the expected answer from the card.
In “Device Manager” I have two COM ports (one “AT port” and one “Trace port”), one Sensor (“Sierra Wireless GNSS Sensor EM7345 4G LTE”) and one Network adapter (“Sierra Wireless EM7345 4G LTE”)
The operating system is Windows 8.1 64bit.
what exactly is your issue? you didn’t find AT command for GPS or you are not able to see NMEA port?
You can find the AT command guide from: http://source.sierrawireless.com/resources/airprime/software/airprime—em73xx-7655-8805—at-command-reference/
what is your AT!CUSTOM? command output?
Regards,
Alex
I try AT!CUSTOM and AT!CUSTOM?
on both the reply was ERROR
I need to receive NMEA data from EM7345 over a COM port to use with an old GPS program.
The GPS data from de windows 8.1 sensor “Windows Location Provider” are ok even with WiFi card and WAN card disconnected from WiFi or 4G network
