Hi. I have setup a broadcast (every minute) from a Sutron XLink500 datalogger over an AirLinkRV55 using the serial port. It’s working; I receive the data on my database. However, I can’t remotely connect to the XLink500 over the port 8080. I think that my port forwarding setup isn’t good. Does anyone have screenshots or hints from a similar application ? Thank you
Hi @spprtshc ,
Welcome you to our community! Please go through the topic and share your result.
Hi LemonGreen. It’s not the same application I think. My XLink500 doesn’t have any Ethernet port. I am using the DB9 serial port. My AirLink RV55 has a static IP address. I would like to access the XLink500 over the port 8080 using that static IP address of the AirLink RV55.
Thank you
