Adjust TX power level
During EMC qualification for CE marking HL8548 is not able to connect to CMU base station. Tx signal from the chip is not enough to allow connection. Is ther a way to control TX power from an HL8548 with AT commands for example?
Thanks in advance for your answer.
Regards,
Hi @fabio.furlan,
Please refer to +WMTXPOWER Command described in document to set power level
Please share any concerns you have and help tick Solution if your question is answered
Thanks for your answer, I will check.
Regards.
