Hi all,
I had a requirement to reduce the RF tx power to down below 1w if used a big external antenna.
Is there an AT command or open AT function to do this?
Thanks and Regards
Hi all,
Thanks and Regards
You cannot change. modify/influence how much power the unit will transmit in normal operation (other than by sticking attentuators on it) as the unit has obligations to meet as per its declared capabilities to the network.
