A-gps & xm0110 ttf
I am Using SL6087 with XM0110, Modem & GPS is connected in i2c configuration. How to implement A-GPS feature.
XM0110 TTF is too high 3 to 5 min, How this can be reduced, is there any recommended GPS antenna for XM0110 GPS Chip.
I assume you can use +GPSAID command in the extended AT plugin.
3 to 5 mins for First fix is much longer than mentioned XM0110 PTS…
http://developer.sierrawireless.com/en/Resources/Resources/AirPrime/Hardware_specs_user_guides/AirPrime_XM0110_Product_Technical_Specification_and_Customer_Design_Guidelines.aspx
Are you test using XM0110 & SL6087 dev.kit?
For info, below application available for AGPS and debug:
http://developer.sierrawireless.com/en/Resources/Resources/AirPrime/Application_Notes_and_Code_Samples/AirPrime%20-%20XM0110%20-%20GPS%20Aiding%20-%20Application%20Note.aspx
http://developer.sierrawireless.com/en/Resources/Resources/AirPrime/Application_Notes_and_Code_Samples/AirPrime%20-%20XM0110%20-%20GPS%20Performances%20Debug%20-%20Application%20note.aspx
hope it helps.
