sierrawireless.custhelp.com/app/ … l/a_id/777
It should be made clear that Hyperterminal is not mandatory - anything that supports XMODEM will do!
This is also not mandatory; other speeds can be used if the serial port supports them.
Obviously, the higher the speed, the quicker the download
This one is mandatory - and this should be emphasised
Needs to expain how to obtain the necessary files in DWL format - since the SiWi downloads site only provides .wpk files!
There should also be some notes about using the USB port…
