Hi everyone, this is my first post so please direct me if I am in the wrong category.
I received my MangOH yellow WP7702 development board two days ago and started playing around. Unfortunately I made a huge mistake and upgraded the firmware to the latest version 2.1.0 (octave_2.1.0_wp77xx) It cannot be rolled back via the Octave web tool and the device is no longer connecting to the platform. I can Ping it in Command prompt, however “# hello” yields " Not found" How can I get it back to Version 1 (Release 6) ?
My understanding is that I need either the WP77xx_Release6_GENERIC_test.exe to perform the upgrade via Windows or via WP77xx_Release6_GENERIC_test.spk However this is not available at source for download.
Is the the correct approach? and if not what should I be doing?
Hi Senso,
The question is: do you want to use Octave?
If you want to use Octave, you need to reinstall the firmware (.spk) that was provided with your mangOH Yellow, from mangOH Yellow website (https://mangoh.io/mangoh-yellow-resources-software). Note: WP77xx generic releases are pure module FW: they don’t contain Octave on them.
Also, in that case, I suggest that you change the category of your topic to “Octave”.
Thank you @thibs, I do plan to use Octave and just changed the topic back on your recommendation.
I am not sure how I missed the firmware image on the website, thanks again. I will try it tonight and update the tread.
