[WP7609] How to customize the firmware for modified HW
Hi @jyijyi, I am helping @allent with this issue…
So basically, this is our current situation.
We updated our custom board to use the very same pins the mangoh green devkit uses to control the TI WiFi module WL18.
  • WLAN_EN is connected to GPIO8 (IOT0_GPIO4).
  • /etc/init.d/tiwifi was modified to bypass the IOEXPANDERS (our hardware does not have chip select, etc)
  • The yocto image was modified to generate 1.8V instead of 3.3V, as we don’t have the stepdown the devkit has.
But when we try to run wifi ap start, we get the following:
    Jan  6 01:14:59 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=main | LE_FILENAME ExtractFileDescriptor() 34 | Received fd (11).
    Jan  6 01:14:59 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=main | LE_FILENAME ExtractFileDescriptor() 34 | Received fd (12).
    Jan  6 01:14:59 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/daemon T=main | pa_wifi_ap_ti.c pa_wifiAp_Start() 469 | Starting AP, SSID: wifiAPssid
    Jan  6 01:14:59 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=main | LE_FILENAME le_mem_ForceAlloc() 841 | Memory pool 'framework.DestructorObjs' overflowed. Expanded to 2 blocks.
    Jan  6 01:14:59 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=WifiApPaThread | LE_FILENAME PThreadStartRoutine() 365 | Set nice level to 0.
    Jan  6 01:14:59 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=WifiApPaThread | LE_FILENAME le_mem_ForceAlloc() 841 | Memory pool 'framework.DestructorObjs' overflowed. Expanded to 3 blocks.
    Jan  6 01:14:59 swi-mdm9x28-wp user.info Legato:  INFO | wifiService[1005]/daemon T=WifiApPaThread | pa_wifi_ap_ti.c WifiApPaThreadMain() 243 | Started!
    Jan  6 01:14:59 swi-mdm9x28-wp user.info Legato:  INFO | wifiService[1005]/daemon T=WifiApPaThread | pa_wifi_ap_ti.c WifiApPaThreadMain() 260 | PARSING:WIFI_SET_EVENT : len:15
    Jan  6 01:14:59 swi-mdm9x28-wp user.info Legato:  INFO | wifiService[1005] | WIFI_START
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319480] cfg80211: Calling CRDA to update world regulatory domain
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319599] cfg80211: World regulatory domain updated:
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319611] cfg80211:  DFS Master region: unset
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319621] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319634] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319645] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319656] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319667] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319678] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319689] cfg80211:   (5490000 KHz - 5710000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319700] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:14:59 swi-mdm9x28-wp user.info kernel: [  420.319711] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    Jan  6 01:15:01 swi-mdm9x28-wp cron.info crond[1340]: (*system*) RELOAD (/etc/crontab)
    Jan  6 01:15:05 swi-mdm9x28-wp user.info Legato:  INFO | wifiService[1005] | Failed to start TI wifi1
    Jan  6 01:15:05 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[1005]/daemon T=main | pa_wifi_ap_ti.c pa_wifiAp_Start() 484 | WiFi AP Command Failed: (23296)wlan0 WIFI_START
    Jan  6 01:15:05 swi-mdm9x28-wp user.info Legato:  INFO | supervisor[840]/supervisor T=main | supervisor.c SigChildHandler() 784 | Reaping unconfigured child process 2374.
    Jan  6 01:15:05 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[1005]/daemon T=WifiApPaThread | pa_wifi_ap_ti.c ThreadDestructor() 192 | Unable to kill the WIFI events script
    Jan  6 01:15:05 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=main | le_wifiAp_server.c CleanupClientData() 148 | Client 0x7f57d7ec is closed !!!
    Jan  6 01:15:05 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/daemon T=main | le_wifiClient.c CloseSessionEventHandler() 478 | sessionRef 0x7f57d75c GetFirstSessionRef (nil)
    Jan  6 01:15:05 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1005]/framework T=main | le_wifiClient_server.c CleanupClientData() 148 | Client 0x7f57d75c is closed !!!
So in a nutshell, /etc/init.d/tiwifi loads these 3 kernel objects
modprobe wlcore
modprobe wlcore_sdio
modprobe wl18xx
Waits 5 seconds, looks for WLAN0 interface and throws error “Failed to start TI wifi1” because the interface is not found…
The thing is… We are probing WLAN_EN and the driver is not even trying to pull it high when “wifi ap start” is issued.
We then tried to manually set WLAN_EN high, which indeed causes the pin to be set high, but leads to the following:
    Jan  6 01:57:04 swi-mdm9x28-wp user.info kernel: [  612.881799] cfg80211:   (5490000 KHz - 5710000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:57:04 swi-mdm9x28-wp user.info kernel: [  612.881810] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    Jan  6 01:57:04 swi-mdm9x28-wp user.info kernel: [  612.881822] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    Jan  6 01:57:04 swi-mdm9x28-wp user.debug kernel: [  612.910683] gpio_sync_ri: RI owner is Modem
    Jan  6 01:57:04 swi-mdm9x28-wp user.debug kernel: [  612.910709] gpio_map_name_to_num: find GPIO 58
    Jan  6 01:57:04 swi-mdm9x28-wp user.debug kernel: [  612.910720] export_store: Export GPIO: 58
    Jan  6 01:57:04 swi-mdm9x28-wp user.debug kernel: [  612.910747] gpio_sync_ri: RI owner is Modem
    Jan  6 01:57:04 swi-mdm9x28-wp user.debug kernel: [  612.910762] gpiod_export: sierra--find GPIO,chipdev = -824019952,chipngpio = 80,chipbase = 0
    Jan  6 01:57:04 swi-mdm9x28-wp user.warn kernel: [  613.804345] sdhci_msm 7864900.sdhci: card claims to support voltages below defined range
    Jan  6 01:57:04 swi-mdm9x28-wp user.warn kernel: [  613.864325] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
    Jan  6 01:57:04 swi-mdm9x28-wp user.info kernel: [  613.867344] mmc0: new high speed SDIO card at address 0001
    Jan  6 01:57:05 swi-mdm9x28-wp user.debug kernel: [  614.033770] gpio-58 (sysfs): gpiod_request: status -16
    Jan  6 01:57:05 swi-mdm9x28-wp user.err kernel: [  614.033794] wlcore: ERROR cannot assign WLAN_EN GPIO58.
    Jan  6 01:57:05 swi-mdm9x28-wp user.warn kernel: [  614.050497] wl18xx_driver: probe of wl18xx.0.auto failed with error -16
    Jan  6 01:57:09 swi-mdm9x28-wp user.info Legato:  INFO | wifiService[1002] | Failed to start TI wifi1
    Jan  6 01:57:09 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[1002]/daemon T=main | pa_wifi_ap_ti.c pa_wifiAp_Start() 484 | WiFi AP Command Failed: (23296)wlan0 WIFI_START
    Jan  6 01:57:09 swi-mdm9x28-wp user.info Legato:  INFO | supervisor[838]/supervisor T=main | supervisor.c SigChildHandler() 784 | Reaping unconfigured child process 2910.
    Jan  6 01:57:09 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[1002]/daemon T=WifiApPaThread | pa_wifi_ap_ti.c ThreadDestructor() 192 | Unable to kill the WIFI events script
    Jan  6 01:57:09 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1002]/framework T=main | le_wifiAp_server.c CleanupClientData() 148 | Client 0x7f57d7ec is closed !!!
    Jan  6 01:57:09 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1002]/daemon T=main | le_wifiClient.c CloseSessionEventHandler() 478 | sessionRef 0x7f57d75c GetFirstSessionRef (nil)
    Jan  6 01:57:09 swi-mdm9x28-wp user.debug Legato:  DBUG | wifiService[1002]/framework T=main | le_wifiClient_server.c CleanupClientData() 148 | Client 0x7f57d75c is closed !!!
Which means the driver is indeed trying to take control of GPIO8 (IOT0_GPIO4, exported as GPIO: 58), and it complains if we drive it high manually.
But at the same time, if not set manually… It is never driven high by the driver.
Do you know what could be causing this?
Thanks in advance,
Here says the wlcore driver will take control of GPIO8:
Also have you checked the voltage of SDIO pin and see if it is really operating in 1.8V?
This thread shows someone modifying the yocto image to change the voltage to be 1.8V:
Currently I am using Mangoh red board for testing the WIFI IOT card, it works fine for me.
I saw in the tiwifi script, it will do the following:
echo “mangOH red board”
           # Set IOT0_GPIO2 = 1 (WP GPIO13)
           [ -d /sys/class/gpio/gpio13 ] || echo 13 >/sys/class/gpio/export
           echo out >/sys/class/gpio/gpio13/direction
           echo 1 >/sys/class/gpio/gpio13/value
           # Set IOT0_RESET = 1 (WP GPIO2)
           [ -d /sys/class/gpio/gpio2 ] || echo 2 >/sys/class/gpio/export
           echo out >/sys/class/gpio/gpio2/direction
           echo 1 >/sys/class/gpio/gpio2/value
           # Clear SDIO_SEL, GPIO#9/EXPANDER#1 - Select the SDIO
           gpioexp 1 9 output normal low >/dev/null || exit 127
so you can double check if it has the same state as your custom board.
Dear friends,Have a nice day.Can we use WP7609 to upgrade to R13.1?
not recommended, better to use R13.3:
https://source.sierrawireless.com/resources/airprime/software/wp76xx/wp76xx-firmware-release-13,-d-,1/#sthash.W2VDss1U.dpbs
Dear friend, thank you for your quick and timely reply. may I know what SKU code corresponds to R13.1 and what SKU code corresponds to R13.3?Thanks in advance.
I don’t see a SKU for WP7609 with R13.1…
For WP7609 with R13.3, you can try SKU 1104559
Dear friend, thank you for the information. So if I buy another SKU code WP7609,may I upgrade to R13.3 to use the R13.3 version function? The production code the WP7609 module we purchased is 2019 year. If we upgrade to R13.3, can we use the VOLTE function?
you can run the windows one click tool exe to upgrade to R13.3
For VoLTE, please see :
Dear friend, may I know the difference between the Generic version and the carrier version?Thank you for your help and support.
The Telstra version is under Telstra approval
OK, thanks. If so, I think the 2019 WP7609 I bought supports VoLTE
Dear friend, thank you so much. may I also use generic R13.3 normally in Australia?
probably you need to make a test
Okay, I understand. I will do some tests as soon as possible.Many thanks.
Dear friend, I am very sorry to bother you again. Does the firmware version of WP7609 SKU 1104558 correspond to R13.3 or other versions? I still have a question about the WP7609 module, what historical firmware versions has Sierra wireless released?
yes, this SKU 1104558 uses FW R13.3
Dear friend,Does SKU 1104559 also refer to WP7609 R13.3? What is the difference between WP7609 SKU 1104558 and SKU 1104559?
1104559 is having GPS feature with FW R13.3
Dear friend, Thank you for your kindness.so if I buy SKU 1104558 WP7609, can I have GPS features? If I want GPS feature with R13.3, do I have to buy SKU 1104559 WP7609? In addition, my current WP7609 SKU is not 1104559 or 1104558, so can I upgrade our WP7609 to R13.3 with GPS features? I can guess that WP7609 SKU 1104558 and WP7609 SKU 1104559 may have different chips. WP7609 SKU 1104559 may be equipped with a GPS chip, while WP7609 SKU 1104558 does not have a GPS chip. Is my guess correct? Looking forward to your reply.
I think you better check with distributor
