I am able to build the kernel source code for wp7608 from the yocto source.
I succesfully flashed the linux distribution with out disturbing the other software components.
Now my question is
Is The device tree part of the yocto_wp76xx.4k.cwe ?
If so could you please let us know the device tree binary name in the build ? I can see the following
Hi @stirulaka, sorry about the slow response. The device tree used for the WP7608 is the mdm9607-wp76xx-mangoh-green. The name isn’t ideal, but is intended as the default tree for MangOH red as well. If you work backwards from the top level DTSI file (kernel/arch/arm/boot/dts/qcom/mdm9607-wp76xx-mangoh-green.dts), you can see some levels of inheritance, if you wanted to replace the mangoh-green top level with a custom platform, or add to it. The resulting DTB is appended to the kernel image, so yocto_wp76xx.4k.cwe is a good way to load it to the target.
By the way, you can get a little evidence of this Device Tree selection in the logs:
dmesg | grep “Machine model”
[ 0.000000] Machine model: Sierra Wireless, Inc. MDM 9607 WP series
That string is coming from the top level DTS file.
