WP7608-1 Module Keeps Restarting and Eventually Switches to DM Port
Hi @jyijyi
Can i know the reason why the Module is restarting and again and again and after that it will stuck in the DM port??
Manu
After redownloading firmware to it, can it be recovered?
hi @jyijyi
Means can you plaese explain in a bit??
Manu
i mean if it can be recovered by firmware download, then that means probably there could be flash corruption
If it still behaves the same, then that could be some hardware issue like power supply not stable etc
hi @jyijyi
Can i know after switching to the DM port i want to flash the FW 16.3 to recover the Module??
Manu
e.g.
you can extract the R16.3 exe by 7zip.
After that you can open a command prompt to the new folder and type “fdt2.exe WP76xx_Release16.3_GENERIC.spk”
BTW, you can also check UART2 console log to see if there is any clue on the reset
hi @jyijyi
Can we downgarde the FW 16. 3 to the 16.0.1 ??
MANU
yes, it should be ok
