We have failed to test the GPS using WP7607 ACC Board. Following is the AT command we used. Using the same command MC7430 can position properly.We have also used Sierra’s GNSS tool and still can’t position.
Please help and give advice.
thanks.
AT!GPSSTATUS?
Current time: 2022 12 05 0 02:59:51
2022 12 05 0 02:59:51 Last Fix Status = NONE
2022 12 05 0 02:57:57 Fix Session Status = ACTIVE
No TTFF available
Yes.
I use an active antenna and send at+want=1
But after a period of time, it still cannot be positioned.
Under the same environment and test method, it can be located on MC7430.
I’ve tried changing locations, antennas and modules to test.
The modules of WP76xx ACC board also cannot be located, but the modules of the MC series can be located.
