How to set GPS for the first time?
How to set GPS for the first time??
the data that i got for
root@swi-mdm9x28-wp:~# gnss get posInfo
TTFF not calculated (Position not fixed)
Position state: No Fix
Latitude(positive->north) : 0.000000
Longitude(positive->east) : 0.000000
hAccuracy : 9999000.32m
Altitude : -18.000m
vAccuracy : 0.0m
AltitudeOnWgs84 : 0.000m
GPS time invalid [0, 0]
Time invalid 00:00:00.000
Time invalid 0 ms
GPS time accuracy invalid [65535]
Date invalid 0000-00-00
Position dilution of precision (PDOP) invalid 65535
Horizontal dilution of precision (HDOP) invalid 65535
Vertical dilution of precision (VDOP) invalid 65535
Geometric dilution of precision (GDOP) invalid 65535
Time dilution of precision (TDOP) invalid 65535
hSpeed invalid [4294967295, 8164]
vSpeed invalid [2147483647, 5773]
Direction invalid [4294967295, 4294967295]
how about
gnss start
gnss fix 180
root@swi-mdm9x28-wp:~# gnss start
The GNSS device is already started
root@swi-mdm9x28-wp:~# gnss fix 180
does I have to set any at! command or another setting ??
you can try
AT!GPSEND=0
AT!GPSFIX=1,180,1000
AT!GPSEND=0
ErrCode = 15
it’s still got the same result.
Altitude : -18.000m
vAccuracy : 0.0m
Time invalid 0 ms
root@swi-mdm9x28-wp:~# gnss get satStat
satsInView 21 - satsTracking 20 - satsUsed 0
at!gpsstatus?
Current time: 2022 01 11 1 09:54:01
1980 01 06 6 00:00:00 Last Fix Status = FAIL, FAILCODE = 9
1980 01 06 6 00:00:00 Fix Session Status = FAIL, FAILCODE = 9
No TTFF available
Did you enable gps in at!custom?
yes, it already enable
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
SIMHOTSWAPDIS 0x02
CFUNPERSISTEN 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
USBSERIALENABLE 0x01
PCSCDISABLE 0x07
CSVOICEREJECT 0x02
SINGLEAPNSWITCH 0x01
TXONINDICATION 0x01
HSICENABLE 0x01
SCRUBEN 0x01
EXTGPSLNAEN 0x01
CSDDISABLE 0x01
I don’t see problem with WP7609 here:
at!gpsend=0
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
CSVOICEREJECT 0x02
TXONINDICATION 0x01
HSICENABLE 0x01
SCRUBEN 0x01
STKUIEN 0x02
EXTGPSLNAEN 0x01
CSDDISABLE 0x01
at!gpsfix=1,180,1000
ati3
Model: WP7609
Revision: SWI9X07Y_02.28.03.03 000000 jenkins 2019/05/21 03:33:04
IMEI: 359782080100373
IMEI SV: 6
FSN: WA803370311610
+GCAP: +CGSM
this what i got:
at!gpssend=0
ERROR
ErrCode = 15
ati3
Model: WP7605
Revision: SWI9X07Y_02.28.03.05 000000 jenkins 2019/07/08 11:04:16
IMEI: 353532100628937
IMEI SV: 6
FSN: 2A140630311110
+GCAP: +CGSM
what is the AT+CFUN?
at+CFUN?
+CFUN: 1
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
SIMHOTSWAPDIS 0x02
CFUNPERSISTEN 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
PCSCDISABLE 0x07
CSVOICEREJECT 0x02
TXONINDICATION 0x01
HSICENABLE 0x01
SCRUBEN 0x01
EXTGPSLNAEN 0x01
CSDDISABLE 0x01
at!gpsfix=1,180,10000
+CREG: 0
+CGREG: 0
+CEREG: 0
ati3
Model: WP7605
IMEI: 353532100020465
IMEI SV: 6
FSN: 2A917285070404
+GCAP: +CGSM
at+cfun?
+CFUN: 1
my result:
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
SIMHOTSWAPDIS 0x02
CFUNPERSISTEN 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
PCSCDISABLE 0x07
CSVOICEREJECT 0x02
TXONINDICATION 0x01
HSICENABLE 0x01
SCRUBEN 0x01
EXTGPSLNAEN 0x01
CSDDISABLE 0x01
ERROR
ati3
Model: WP7605
IMEI SV: 6
FSN: 2A140630311110
+GCAP: +CGSM
at+cfun?
+CFUN: 1
Could you please tell me ,How you install to frameware which file did you have used??
I just use the one-click EXE of FW R13.3 in Windows
it still have the same result as before :
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
SIMHOTSWAPDIS 0x02
CFUNPERSISTEN 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
PCSCDISABLE 0x07
CSVOICEREJECT 0x02
TXONINDICATION 0x01
HSICENABLE 0x01
SCRUBEN 0x01
EXTGPSLNAEN 0x01
CSDDISABLE 0x01
at+cfun
ERROR
at+cfun?
+CFUN: 1
ati3
Model: WP7605
IMEI SV: 6
FSN: 2A140630311110
+GCAP: +CGSM
ERROR
and i cannot connect internet any more
no idea as I don’t see this problem , maybe you try another module and see if the result is the same
at!custom?
!CUSTOM:
GPSENABLE 0x01
GPSLPM 0x01
IPV6ENABLE 0x01
SIMHOTSWAPDIS 0x02
CFUNPERSISTEN 0x01
UIM2ENABLE 0x01
SIMLPM 0x01
PCSCDISABLE 0x07
CSVOICEREJECT 0x02
TXONINDICATION 0x01
HSICENABLE 0x01
SCRUBEN 0x01
EXTGPSLNAEN 0x01
CSDDISABLE 0x01
ati3
Model: WP7605
IMEI SV: 6
FSN: 2A917285070404
+GCAP: +CGSM
at+cfun?
+CFUN: 1
but still cannot get the position
satsInView 18 - satsTracking 14 - satsUsed 0
which command the order to used sat??
Did you go outdoor with gps antenna connected?
What is the return of
at!gpssatinfo?
AT!GPSSTATUS?
