How to set GPS for the first time?
at
at!gpssatinfo?
NO SAT INFO
at!gpsstatus?
Current time: 2022 01 13 3 00:41:24
2022 01 13 3 00:41:16 Last Fix Status = FAIL, FAILCODE = 12
2022 01 13 3 00:41:16 Fix Session Status = ACTIVE
No TTFF available
Then it cannot view satellite
how to get the satellite info??
you need to have gps antenna connected and outdoor environment.
do you know how to power on gps by using at command??
when you type AT!GPSFIX, it will be power on
at!gpstrack=1,255,1000,30,1
AT!GPSSTATUS?
Current time: 2022 01 19 2 08:27:50
2022 01 19 2 08:27:17 Last Fix Status = FAIL, FAILCODE = 9
2022 01 19 2 08:27:44 Fix Session Status = ACTIVE
No TTFF available
at!gpsloc?
Not Available
AT!GPSFIX=1, 15, 10
ERROR
i got error
when it is on AT!GPSTRACK, you cannot do AT!GPSFIX
what should i have to set for !gpsend
maybe you start with AT!GPSFIX instead of AT!GPSTRACK first after power on
how to know that the power is already on after at!gpsfix is ok
you can check if there is NMEA frame coming out in NMEA port
how to check NMEA port??
use terminal program to open the USB serial port for NMEA frame.
