Hi everyone, ![]()
I am having problems to create new projects. Every time that I try to create a new one using the Open AT Project Wizard, I got the following error:
Wavecom sent me a file that says how to fix it (see at the end of the topic), but I am having problem on step 6 and 7.
There is not VUSR_*** at my passwd file
The command “wmsetup” is not creating the home directory.
Anyone can help me on that ???
Thanks for all,
Gustavo Nunes
Delete the old cygwin folder (with all its contents) and reinstall Open AT with complete installation of cygwin (By selecting “Install†option for all the packages).
Delete “passwd†and “group†files from etc folder of cygwin directory. Also delete the “home†folder if present in cygwin directory.
Open the cygwin window (Or cygwin.bat file from cygwin directory) and execute the command mkgroup –l > /etc/group. Then execute the command mkpasswd –l > /etc/passwd. These commands will recreate “passwd†and “group†files in the etc folder of cygwin directory. Close the cygwin window.
Now open the “group†file present in the etc directory of cygwin and add the following line in it:
Everyone:S-1-1-0:0:
This line should be the first line of “group†file. Save and close the group file. -
Open the “passwd†file present in the etc directory of cygwin. This file will contain some entries starting with VUSR_computername (for example VUSR_wavecom-regis4, VUSR_wavecom-regis3 etc).
Edit one such line by replacing VUSR_computername (in complete line) by the user login name. (For example replace VSUR_wavecom-regis4 by rma). Save and close the file.
Now open the cygwin window and execute wmsetup command. It will recreate the “home†folder in cygwin directory and will resolve the problem.
