I’m having an error when i’m trying to run a sample project
“Wmnew script error 3 (bad environment settings)”
How can i fix this problem?
Thanks!
Thanks!
Hi takis,
when installing cygwin, did you select that all packages should be installed?
Best Regards,
Jan
When I first installed the SDK I had the same problem.
In my case the McAffee Virus scanner was running during the installation so the setup couldn’t write all settings. So I disabled McAffee and run the setup again. Now everything works fine.
