Sierra Wireless AirLink Antenna: 6-in-1 SharkFin 6001262
Sierra Wireless MP70 Router
Panasonic CF-19 Mk6 Toughpad in Gamber-Johnson Docking Station
Toughpad WI-FI switch turned off. <<<<<<<<<<
Ethernet Patch Cable from MP70 Router through Docking Station to Toughpad
Is this how these get hooked together while avoiding pitfalls?
(Toughpad WI-FI switch off so it does not get overloaded from MP70 Wi-Fi)???
Any other tricks?
Is there any publication that shows how to hook all this stuff together?
The MP70 broadcasts on Wi-Fi. The MP70 will be sitting close by the Toughbook which will be listening on Wi-Fi unless I shut Wi-Fi off. Sounds like an unnecessary overload to me.
Toughbook has an MC7355 and GPS antenna. The MP70 has an MC7455 which supports GPS and Wi-Fi. Will there be any kind of conflict with these two when the MP70 is connected to the Dock through the Ethernet cable and thence to the Toughbook.
Found a place to print it for $50+.
My confusion persists. As I said the MP70 has a MC7455 in it. The Toughbook has an MC7355 in it.
If the MP70 already defines what network and GPS is passed through to the toughbook, then the
need for the MC7355 is no longer necessary??? Is it shut off by switching the WI-FI off??
I looked through the manual you suggested. Does not address my question.
I assume I do not need SIM in toughbook as SIM in MP70 defines connections.
The Gamber Johnson dock has 2 antenna connections WLAN and GPS. The MP70 has 6 antenna outputs so I don’t want to fool around with those so I will use CAT6 Patch Cable RJ45M/RJ45M to connect MP70 to Dock and thence through Dock to the Toughbook. How I get this to work, I don’t know yet but I assume that is what the patch cable and connectors are for. Now I just need to learn how to communicate with the MP70.
Robert
I tried finding information in the like manual you cited. Nothing on RJ-45 or patch cable so I don’t know know what the communication between these units is…
