Hello everybody,
We want to create an internet connexion using gprs wavecom modem.
modem has open at enabled
model do not have edsoft nor wipsoft
where may i find them
, how to install them into the modem ?
thanks in advance
Hello everybody,
thanks in advance
It must be at least 6 years since edsoft was replaced by WIP
Hi, thaks
I have an old modem for testing purposes.
Is it possible to install wipsoft ? where can i find it ?
could you please give som help on that
That is going to be an adventure in computer archaeology ![]()
Unless you are particularly good at, and find particular pleasure in, seeking-out old & obsolete components, software, documentation and tools - I would strongly suggest that you would do far better with a modern modem for which tools, documentation, software, and support are readily available…
Well it is not possible to buy new modems in the test phase.
Thanks anyway, i will continue looking for this issue and let you know if i find a solution for it
Hi Sam,
Please list the exact model number and firmware running, but as you mentioned “edsoft”… I believe it is very old…
If you obtained it from a distributor previously, please try to contact them.
Otherwise, I believe a recent module make more sense for development and even for testing and proof-of-concept purpose as latest software will have better performance and features available.
Depends on your location and carrier available, below maybe a good start:
http://developer.sierrawireless.com/Ecosystem/Partners.aspx#&&filter=PartnerCategories-eq-(D4CBEA24-53E4-46A5-89B8-6C7AF3F4A5F1)
Good luck!
L
The amount of time you could waste in trying to track this stuff down could mean that you won’t have time to do anything else ![]()
If this is a commercial project, the cost of that time will certainly exceed the cost of a new modem ![]()
If it’s a really old modem that don’t have any upgrade path to firmware that wipsoft can run on, you’re SOL.
eDSoft can’t be distributed through any official channels any more.
HI all
here are the information : wavecom M1306B
AT+CGMR gives
AT+641b09gg.Q2406B 1339080 041604 16:04
and AT+WOPEN=2 gives
+WOPEN: 2, “AT v2.10”, “AT v2.10”
IIRC, the M1306B uses a Q2406B module, and was supported by Open-AT up to about v3.3 - which included the first versions of WIP.
You will need the old tools for this - it doesn’t work with Developer Studio.
so i have to look for at v 3.3 ?
i tried AT+WIPCFG=1 it gives an error
please do you know where can i get the wipsoft.dwl ?
thanks
Attached find some old Versions of WIPsoft. Use at your own risk!
best regards,
Gregor Bader
Good to know the modem is M1306B, although it is still old products…
v3 in the archive maybe a good start.
[url]http://archive.sierrawireless.com/Default.aspx?Folder=\AirPrime\Open_AT_SDK_All_devices[/url]
Good luck.
Thanks a lot for these files. I tried to upload the .dwl file to the modem using the HYPETERMINAL
but the transfert is stopped; and I get a message from hyperterminal saying that the remote system stopped the transfert. May be this means that the file is not compatible with the modem version ![]()
thanks lotam and gregorbader
