My customer encountered an issue using a modem that uses the SL8082T module on Windows 2016. Windows crashed and the issue appears to be with swiwdmbx64.sys. I’m using the USB driver from this page - https://source.sierrawireless.com/resources/airprime/tools/airprime---usb-driver-for-windows-7-and--8,-d-,1_sl808xt-series/#sthash.CIVMfD1P.H7ycrmJx.dpbs
Has anyone encountered a similar situation and if there’s a way to avoid this, or at least prevent Windows from crashing? Or is there another driver that I can use? I know this is a tricky question, but I would appreciate any pointers. Thank you very much.
!analyze -show
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses.
Arguments:
Arg1: 0000000000000040, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8028b64530e, address which referenced memory
!mex.t ffffbb8b92805040
Process Thread CID UserTime KernelTime ContextSwitches Wait Reason Time State
System (ffffbb8b88899040) ffffbb8b92805040 (E|K|W|R|V) 4.407c 0 156ms 28944 Executive 46ms Running on processor 1
Priority:
Current Base Decrement ForegroundBoost IO Page
12 12 0 0 0 5
Child-SP Return Call Site Source
0 ffffce01e6e76158 fffff8028b76ce29 nt!KeBugCheckEx
1 ffffce01e6e76160 fffff8028b76b407 nt!KiBugCheckDispatch+0x69
2 ffffce01e6e762a0 fffff8028b64530e nt!KiPageFault+0x247
3 ffffce01e6e76430 fffff80a9b518dfd nt!IopfCompleteRequest+0x42e
4 ffffce01e6e76550 fffff8028b644ff2 swiwdmbx64+0x8dfd
5 ffffce01e6e765c0 fffff80a980a6907 nt!IopfCompleteRequest+0x112
6 (Inline) ---------------- Wdf01000!FxIrp::CompleteRequest+0xd d:\rs1\minkernel\wdf\framework\shared\inc\private\km\fxirpkm.hpp @ 75
7 ffffce01e6e766e0 fffff80a980b21c4 Wdf01000!FxRequest::CompleteInternal+0x247 d:\rs1\minkernel\wdf\framework\shared\core\fxrequest.cpp @ 871
8 (Inline) ---------------- Wdf01000!FxRequest::CompleteWithInformation+0x18 d:\rs1\minkernel\wdf\framework\shared\inc\private\common\fxrequest.hpp @ 820
9 ffffce01e6e76790 fffff80a980b243c Wdf01000!FxIoQueue::CancelForQueue+0x94 d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxioqueue.cpp @ 4433
a ffffce01e6e767f0 fffff80a980b1faf Wdf01000!FxIoQueue::QueuePurge+0x1b8 d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxioqueue.cpp @ 4054
b ffffce01e6e76860 fffff80a9a234c0c Wdf01000!imp_WdfIoQueuePurge+0x3f d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxioqueueapi.cpp @ 1261
c ffffce01e6e768a0 fffff80a9a29381d USBXHCI!Endpoint_UcxEvtEndpointPurge+0x14c
d ffffce01e6e76900 fffff80a9a2926e1 ucx01000!UcxEndpointStateEntryFunc_Purging1+0x1d
e ffffce01e6e76930 fffff80a9a2888c5 ucx01000!StateMachineEngine_EventAdd+0x3e1
f ffffce01e6e76990 fffff80a9a2897fc ucx01000!UsbDevice_CallAddEventForAllEndpointsWithPendingOperationSet+0x195
10 ffffce01e6e76a00 fffff80a9a28ab0a ucx01000!UsbDevice_PurgeFromHub+0x90
11 ffffce01e6e76a40 fffff80a980ab609 ucx01000!UsbDevice_EvtMgmtIoInternalDeviceControl+0x76a
12 (Inline) ---------------- Wdf01000!FxIoQueueIoInternalDeviceControl::Invoke+0x43 d:\rs1\minkernel\wdf\framework\shared\inc\private\common\fxioqueuecallbacks.hpp @ 267
13 ffffce01e6e76c20 fffff80a980aa7aa Wdf01000!FxIoQueue::DispatchRequestToDriver+0x289 d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxioqueue.cpp @ 3340
14 ffffce01e6e76cc0 fffff80a980bb5d2 Wdf01000!FxIoQueue::DispatchEvents+0x3aa d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxioqueue.cpp @ 3122
15 (Inline) ---------------- Wdf01000!FxIoQueue::QueueRequest+0x86 d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxioqueue.cpp @ 2364
16 (Inline) ---------------- Wdf01000!FxPkgIo::DispatchStep2+0x498 d:\rs1\minkernel\wdf\framework\shared\irphandlers\io\fxpkgio.cpp @ 469
17 ffffce01e6e76d90 fffff80a9a2855b8 Wdf01000!imp_WdfDeviceWdmDispatchIrpToIoQueue+0x622 d:\rs1\minkernel\wdf\framework\shared\core\km\fxdeviceapikm.cpp @ 494
18 ffffce01e6e76e70 fffff80a980a3b8c ucx01000!RootHub_Pdo_EvtInternalDeviceControlIrpPreprocessCallback+0x768
19 (Inline) ---------------- Wdf01000!PreprocessIrp+0x34 d:\rs1\minkernel\wdf\framework\shared\core\fxdevice.cpp @ 1502
1a (Inline) ---------------- Wdf01000!DispatchWorker+0x776 d:\rs1\minkernel\wdf\framework\shared\core\fxdevice.cpp @ 1565
1b (Inline) ---------------- Wdf01000!FxDevice::Dispatch+0x782 d:\rs1\minkernel\wdf\framework\shared\core\fxdevice.cpp @ 1586
1c ffffce01e6e76f00 fffff80a980aec04 Wdf01000!FxDevice::DispatchWithLock+0x7ec d:\rs1\minkernel\wdf\framework\shared\core\fxdevice.cpp @ 1430
1d (Inline) ---------------- Wdf01000!FxIoTarget::Send+0xd d:\rs1\minkernel\wdf\framework\shared\inc\private\km\fxiotargetkm.hpp @ 267
1e ffffce01e6e76ff0 fffff80a9a3dcf36 Wdf01000!imp_WdfRequestSend+0x164 d:\rs1\minkernel\wdf\framework\shared\core\fxrequestapi.cpp @ 2101
1f ffffce01e6e77080 fffff80a9a3df0bc UsbHub3!HUBUCX_SubmitUcxIoctl+0x16a
20 ffffce01e6e77110 fffff80a9a3d759d UsbHub3!HUBUCX_PurgeDeviceIoUsingUCXIoctl+0x70
21 ffffce01e6e77150 fffff80a9a3c90f3 UsbHub3!HUBDSM_PurgingDeviceIoOnDetachInConfigured+0x1d
22 ffffce01e6e77180 fffff80a9a3ca1f6 UsbHub3!HUBSM_ExecuteEntryFunctionsAndPushPopStateMachinesForCurrentState+0x4b
23 ffffce01e6e77210 fffff80a9a3c9bde UsbHub3!HUBSM_RunStateMachine+0x5f6
24 ffffce01e6e772a0 fffff80a9a3e5e8d UsbHub3!HUBSM_AddEvent+0x3fe
25 ffffce01e6e772f0 fffff80a9a3cdaa0 UsbHub3!HUBMISC_DetachDevice+0x21
26 ffffce01e6e77320 fffff80a9a3c90f3 UsbHub3!HUBPSM20_DetachingDeviceFromPortOnCycleOnHubStop+0x10
27 ffffce01e6e77350 fffff80a9a3ca1f6 UsbHub3!HUBSM_ExecuteEntryFunctionsAndPushPopStateMachinesForCurrentState+0x4b
28 ffffce01e6e773e0 fffff80a9a3c97c2 UsbHub3!HUBSM_RunStateMachine+0x5f6
29 ffffce01e6e77470 fffff80a9a28fac4 UsbHub3!HUBSM_EvtSmWorkItem+0x42
2a ffffce01e6e774a0 fffff8028b6b6011 ucx01000!Controller_ForwardProgressWorkItemCallback+0x5c
2b ffffce01e6e774d0 fffff8028b678bd9 nt!IopProcessWorkItem+0x81
2c ffffce01e6e77540 fffff8028b6c9765 nt!ExpWorkerThread+0xe9
2d ffffce01e6e775d0 fffff8028b7671a6 nt!PspSystemThreadStartup+0x41
2e ffffce01e6e77620 0000000000000000 nt!KiStartSystemThread+0x16
lmvm swiwdmbx64
Browse full module list
start end module name
fffff80a9b510000 fffff80a9b52ab00 swiwdmbx64 (no symbols)
Loaded symbol image file: swiwdmbx64.sys
Image path: \SystemRoot\System32\drivers\swiwdmbx64.sys
Image name: swiwdmbx64.sys
