I’m trying to install “OpenAT Software Suite 2.31 - FullInstaller” under Windows 7 x64 version. I’m getting the following error (retrieved from the log) and i can’t continue to perform a successfull install:
[i]!SESSION 2010-03-17 12:23:28.353 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_17
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
Framework arguments:
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2010-03-17 12:23:31.919
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application “com.anwrt.p2.installer.application” could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.director.app.application, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.installer.application, org.eclipse.equinox.p2.metadata.generator.EclipseGenerator, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
!ENTRY org.eclipse.osgi 2 0 2010-03-17 12:23:31.932
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-17 12:23:31.932
!MESSAGE Bundle reference:file:plugins/org.sf.feeling.swt.win32.extension_1.0.5.jar was not resolved.
!SUBENTRY 2 org.sf.feeling.swt.win32.extension 2 0 2010-03-17 12:23:31.932
!MESSAGE Missing host Bundle-NativeCode_0.0.0.
!ENTRY org.eclipse.osgi 2 0 2010-03-17 12:23:31.934
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2010-03-17 12:23:31.934
!MESSAGE Bundle com.anwrt.p2.installer_1.0.2.200912171336-R3437 [2] was not resolved.
!SUBENTRY 2 com.anwrt.p2.installer 2 0 2010-03-17 12:23:31.934
!MESSAGE Missing required bundle org.sf.feeling.swt.win32.extension_1.0.5.
!MESSAGE Bundle com.anwrt.p2.installer.builder_1.0.2.200912171336-R3437 [3] was not resolved.
!SUBENTRY 2 com.anwrt.p2.installer.builder 2 0 2010-03-17 12:23:31.934
!MESSAGE Missing required bundle com.wavecom.openat.ide.installer_1.0.2.
!MESSAGE Bundle com.wavecom.openat.ide.installer_1.0.2.200912171336-R3437 [5] was not resolved.
!SUBENTRY 2 com.wavecom.openat.ide.installer 2 0 2010-03-17 12:23:31.934
!MESSAGE Missing required bundle com.anwrt.p2.installer_1.0.2.
!MESSAGE Bundle org.sf.feeling.swt.win32.extension_1.0.5 [88] was not resolved.
!SUBENTRY 2 org.sf.feeling.swt.win32.extension 2 0 2010-03-17 12:23:31.935
!MESSAGE Missing host Bundle-NativeCode_0.0.0.[/i]
The installation was successfull on Windows XP 32bit version. The problem is on Windows version or 32/64 bit version of seven ?
. Nevertheless, after 7 minutes a window announcing successful installation appeared. I am not sure, if there is any connection between disabling the firewall and the success of the installation.
