I bought FX30 with WP7702 module. I can register it to Octave.
To check LED operation, I performed 1-7 operation on “2. Commanding Resources” in the following URL.
But I did not see green and led resource in Resource windows.
I can see any value in io/config. To see two resource making Service, what part should I check Octave or FX30?
I believe there is a bug in the Octave UI. If you use anything other than the default:
“name”: “LED_USR_GRN”, "res": “LED_USR_GRN”,
“type”: “DO”
“name”: “LED_USR_RED”, "res": “LED_USR_RED”,
“type”: “DO”
The LED resources will not appear in the resource tree unless you use the default names… Please use the default names now for a workaround to the issue. I will submit a ticket to engineering
Thanks. I tried to update Octave 3.3.0 from 3.1.0.
I select Firmwares in DEVICE->details and select 3.3.3 and press “DEPLOY” button.
I think that FX30 tried to update FW by FOTA. But… FOTA did not finish after 3 hour. Module signal is stopping for 1 hour.
How to recovery this behavior.
Note:
I connect USB cable and send AT command. Then, module returned the attached file response. I think that FOTA is succeeded but carrier image is difference. So, FX30 cannot connect network and Octave cannot receive correct information from FX30.
I’m using FX30 on Japan. So, I would like to set default image for Octave. Please let us know how to recovery it.
My FX30 SKU is 1104665.
Hi Takashi-san,
The log you attached shows the device has received the ATT 3.3.0 binary, whereas it should be SIERRA 3.3.0.
I need to check with the Octave back-end team why this happened. Do you use an ECC SIM card ?
Meanwhile you can recover your FX30 by updating it locally:
Please select the 3.3.0 FX30 version (not the ATT one)
Regards,
Nicolas
Our system (Airvantage) indicates that you are using ATT network in Japan, with an ATT sim card. This is why the system picked up the ATT Firmware version.
Can you explain how your offer works ? Why should you not use the ATT APN ?
After updating FW for SWI, I can control user LED.
When I control LED_USR_GRN for GPIO48, FX30 is changed Red.
When I control LED_USR_RED for GPIO47, FX30 is changed green.
Why my environment is mixing LED control between Red and Green?
I used latest FW 3.3.0 now.
