When are the traces saved?
When are the traces actually saved to disk?
i already had a trace running, but i only just enabled the ‘save traces’
the file is created, but even after a couple of new traces did arrive, nothing has yet been saved to disk?
do you use M2MStudio? I have the very same problem with it! but I usually use “target monitoring tool” instead to save TRACES in file!
Are you using 1.1.1?
Just made the test, and the traces are saved to disk correctly…
