I am facing a weird behaviour when using Verizon SIM with MC7455. I have flashed the verizon firmware from Sierra. The firmware version is as follows:
ati
Model: MC7455
Revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
MEID: A000006CF194E9
ESN: 12813463286, 80CD6EF6
IMEI: 359072061147894
IMEI SV: 12
FSN: LQ727390940310
+GCAP: +CGSM
I am using ofono to establish a cellular connection. The ofono is not able to detect the SIM. The logs are as follows:
• /usr/lib/ofono/test/list-modems
[ /sierra_0 ]
Type = hardware
Model = MC7455
Manufacturer = Sierra Wireless, Incorporated
Lockdown = 0
Interfaces = org.ofono.SimManager org.ofono.VoiceCallManager
Serial = 359072061147894
Revision = SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
Online = 0
Emergency = 0
Features = sim
Powered = 1
[ org.ofono.SimManager ]
Present = 0
[ org.ofono.VoiceCallManager ]
EmergencyNumbers = 08 000 999 110 112 911 118 119
As a next step, I tried to check the responses of AT commands:
AT+CPIN?
+CPIN: READY
AT+COPS=?
+COPS: (2,“Verizon Wireless”,“VZW”,“311480”,7),(1,“AT&T”,“AT&T”,“310410”,7),(1,)
aT+CREG?
+CREG: 0,3
From the response of at+creg? we can see that the registration to the network is denied. I thought that’s the problem.
But when i tried to use qmilci tools, I can successfully register to the network and can also access the internet connection. The steps followed are as foloows:
qmicli -d /dev/cdc-wdm1 --dms-set-operating-mode=online
[/dev/cdc-wdm1] Operating mode set successfully
qmi-network /dev/cdc-wdm1 start
Loading profile at /etc/qmi-network.conf…
APN: vzwinternet
APN user: unset
APN password: unset
qmi-proxy: no
Checking data format with 'qmicli -d /dev/cdc-wdm1 --wda-get-data-format '…
Device link layer protocol retrieved: raw-ip
Getting expected data format with ‘qmicli -d /dev/cdc-wdm1 --get-expected-data-f ormat’…
Expected link layer protocol retrieved: 802-3
Updating kernel link layer protocol with ‘qmicli -d /dev/cdc-wdm1 --set-expected -data-format=raw-ip’…
Kernel link layer protocol updated
Starting network with 'qmicli -d /dev/cdc-wdm1 --wds-start-network=apn=‘vzwinternet’ --client-no-release-cid '…
Saving state at /tmp/qmi-network-state-cdc-wdm1… (CID: 35)
Saving state at /tmp/qmi-network-state-cdc-wdm1… (PDH: 63831232)
Network started successfully
root@alen-eval-kit:~# qmicli -d /dev/cdc-wdm1 --wds-get-current-settings
[/dev/cdc-wdm1] Current settings retrieved:
IP Family: IPv4
IPv4 address: 100.100.90.111
IPv4 subnet mask: 255.255.255.224
IPv4 gateway address: 100.100.90.112
IPv4 primary DNS: 198.224.145.135
IPv4 secondary DNS: 198.224.144.135
MTU: 1428
Domains: none
root@alen-eval-kit:~# ifconfig wwan1 100.100.90.111 netmask 255.255.255.224
root@alen-eval-kit:~# route add default gw 100.100.90.112 wwan1
root@alen-eval-kit:~# echo “nameserver 198.224.145.135” > /etc/resolv.conf
root@alen-eval-kit:~# echo “nameserver 198.224.144.135” >> /etc/resolv.conf
root@alen-eval-kit:~# wget google.com
Connecting to www.google.com (74.125.124.99:80)
index.html 100% |*******************************| 13346 0:00:00 ETA
I am puzzled why the network registration fails with AT commands and when using qmicli I could successfully connect to the internet. Any information on this topic would be helpful.
Thanks & Regards
vinothkumar
