VPN for remote monitoring only
Hi all
I was hoping to establish a vpn from my RV50 network to my vpn server. This connection is to be used for the monitoring of the RV50s. It should not be the default gateway for all devices behind my RV50s.
As I’m planning to do this on some remote RV50s (latest firmware ) sites, I was wondering if anyone has a walkthrough available.
Any help would be appreciated regarding the airlink setup.
Hi @renzo.karsdorp,
Please refer to section 6: VPN Configuration on page 157 of the Software Configuration Guide at the following link to see if it helps you: https://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-rv-series---configuration-guide/#sthash.UIUj4Tza.dpbs
I was also facing the same issue. Thanks for sharing thishttps://source.sierrawireless.com/resources/airlink/software_reference_docs/airlink-rv-series---configuration-guide/#sthash.UIUj4Tza.dpbs
It is really helpful.
Thank you
I successfully set up a VPN from my RV50 network to my VPN server, ensuring it’s dedicated to monitoring the RV50s and not used as the default gateway for other devices. The process involved configuring the VPN on the latest firmware version of the RV50s. For those facing similar challenges, I found that using a detailed walkthrough for the Airlink setup was invaluable. It streamlined the configuration and made the process smooth. If anyone needs specifics or further guidance, I’m happy to share my experience!
